Question about General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane
GE smartwater R.O. system making noise from hole on side of fauce
My RO system is making a whistling noise like an air leak from the weep hole on the left side of the faucet. What could be causing this?
Probably some gunk clogging the drain line. First step would be to remove the drain line from underneath the sink and check to see that it is clear. If it isn't, the next thing that may happen is when it gets completely clogged, water will start shooting out of the weep hole. As an added measure< i would say to force compressed air down the weep hole to clean out any clog in the line that you can't reach.
Posted on Oct 02, 2009
I have a GE PROFILE R/O System with a chrome dispenser; I need a brushed nickel dispense; where can I get one???
An RO drinking water air gap faucet would be the ideal faucet to purchase for your RO system. Here are a few options you can choose from that may come in brushed nickel: http://www.freshwatersystems.com/c-821-ro-drinking-water-air-gap-faucets.aspx
Jul 31, 2010 | General Electric Profile Smartwater Ultra...
Sink tap has overflow going directly into the drain and constantly running. This is a reverse osmosis system that is outside warranty.
If you mean the little weep hole on the tap is leaking? If so, then the drain line connected to the sink drain is clogged. Remove this line and see if it's draining free.(have bucket ready) Most likely it will be where it enters your sink drain at that fitting, clogged with sink drain materials.
Jul 17, 2010 | General Electric GE SmartWater Household...
Whistling noise while driving
If it is whistling while you rev your engine (while parked), then most likely there is a leak or hole in your air intake or vacuum hoses.
Facts:
1. Your car creates a vacuum to constantly receive air from the outside.
2. A whistling noise is created when air travels through a hole.
Check all air pressurized ducts for holes or leaks.
Check air intake system for holes or leaks.
Jan 08, 2010 | 2000 GMC Jimmy
Ro system tank will fill completely
Use this chart to pinpoint your issue and a possible fix. Most replacement parts if necessary can be found at https://www.freshwatersystems.com/c-67-parts-accessories.aspx.
Oct 08, 2009 | General Electric FX18M GE SmartWater...
What noise would the water pump make if is is going bad or is bad on a 2004 aveo
It could be making a whining, screeching, clattering, or even a whistling noise if the problem is a bearing going out, but it doesn't have to make any noise to be faulty. Look at the water pump. Most have a vent hole (or "weep"hole) and if there is any coolant leaking from the water pump, it is defective. Is the vehicle running hot/overheating? Anyway, sure hope this helped and best wishes.
Jul 30, 2009 | 2004 Chevrolet Aveo
GE smartwater R.O. system leaking out weep hole
Same exact problem started for us last night. (Same model, installed by me about four+ years ago) Water was really coming out of the weep hole, and didn't stop until I shut it off at the valve. This happened once before, and all I had to do was clean the drain line adapter, because it gets full of gunk from the disposal over time. But this time that did not do the trick. (Plus there was not all that much gunk this time....) So I was baffled for awhile but came up with this solution.
I hooked up a small length of clear tubing to my cheap-o tire inflater/air compressor. Put the clear tube against the weep hole. Turned on the compressor, and VOILA!, a bunch of gunk that was clogging the drain tube came out. I think when this tube, or the drain line adapter gets clogged, it causes water to go out the weep hole instead of down the drain. (If you don't have a small compressor, then theoretically there is enough air pressure from something like a bicycle pump, and this solution *might* work with one of those. But if you try this, of course only use the DOWNWARD (air-going-outward) pump action...pulling up (inward) would force the clog deeper up the drain tube)
May 28, 2009 | General Electric Profile Smartwater Ultra...
WHISTLING BELOW TURBO
Its surely not turbo, its is somewhere a hole or leak in turbo air filter housing or air inlet pipe that is making noises when turbo sucks air. check the air pipes wheather they are fitted correctly. Take a keen look at air hose and close any hole with silver tape check the hose is fitted correctly in Turbo air filter housing (if not then it makes whistling noise when air is being sucked by turbo) . Clean all air filters and then give it a go.
May 07, 2009 | Peugeot Liberte Cars & Trucks
GE SmartWater RO Filter Tank Leaking?
I had same system under my sink for same amount of time and have since then removed entirely for health reasons related to Ro Systems. Mainly the tanks becomes contaminated [alge build up]and my faimly had constant nagging stomach aches which took a long time to resolve untill we decided to disconnected and throw out our "beloved healthy RO System" and decided to install a bi annual disposable type filter system. If you are expereanceing this I would advise the same as for the leak ,There are so many connections under there and it is usually not the tank but the fittings in lines some where and the reason it looks like the tank is because that is the lowest point the leak has traveled. So check all your fittings and if you decide on simple water filter I will advise you.
Please rate. Thanks jj505
jthomefix
gmail.com
Mar 28, 2009 | General Electric GE SmartWater Household...
My Culligan RO faucet has an ''air gap'' leak. How do I clear the clogged debris causing the water to constantly run? Culligan told me that the Faucet/Air gap is clogged. Need to dislodge the debris.
Normally when it leaks out the weep hole the drain line is plugged under the sink....turn off the ro to where it's not making water, disconnect the drain hose and flush it out....make sure the adapter that's connected to the drain pipe is still lined up with the hole if it was moved the water can't get to the drain.
Mar 17, 2009 | Culligan Under Sink Water Filter
Hot water faucet starts to whistle as it gets hotter
Ajust the stop under sink , or the line to the fixture, to elimate the whistle.
Mar 15, 2009 | General Electric GE SmartWater Household...
General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane Logo
1,587 people viewed this question
Top General Electric Water Filters & Coolers Experts
Tom Chichester
Are you a General Electric Water Filter and Cooler Expert? Answer questions, earn points and help others
