Question about A D S TV Superscan 2 (SFN-201)
Is my tv digital ready?
Superscan dvd/vcr/tv combo, 19 micronhead, mts/sap. Unsure of year I bought it in, I think 2001
    President:
  • 2,559 Answers
If you have cable or satelite hooked up to it now and it works,Then it is digital ready.
Please rate this a fixya
Posted on Feb 13, 2009
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
How do I turn off SAP on a Toshiba TV/VCR/DVD combo
The SAP usually is selected as part of setup so returning to the setup routine should allow you to disable it
Oct 13, 2012 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Sylvania MTS/SAP tv/vcr/dvd combo turning itself off
could be that either the dvd or the vcr are malfunctioning, usually it is the vcr that creates the problem. If you turn tv on and set vol to low see if you can hear the noise of the motor loading or trying to load,with out a tape inside. It may be a good idea to have a qualified tech repair it, these units are difficult to work on and further problems may come up if you are not familiar with the tv.
Dec 31, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
My Superscan tv will not stay on. How do I fix it?
the vcr tape mechanism may not be all the way up or the tape sensors need to be cleaned or replaced
you can test for voltage on the sensors and test each sensor for an open
electech
Nov 26, 2008 | A D S TV Superscan 2 (SFN-201)
Analog or Digital?
This tv is analog, EDTV is only enhanced definition tv ,480p resolution, not the HDTV 1080i or 1080p resolution, the mts/sap tuner has to do with the audio decoder. For example: SAP would allow you to view a station broadcast in english to be heard in spanish. MTS is surround sound broadcast. Thanks
Apr 02, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
I need a remote Code
The comcast remote control code for Superscan VCR/DVD combo is 11963
Dec 27, 2007 | Televison & Video
A D S TV Superscan 2 (SFN-201) Logo
222 people viewed this question
Top A D S Televison & Video Experts
Are you an A D S Televison and Video Expert? Answer questions, earn points and help others
