Question about Polaroid DRM-2001G DVD Recorder/HDD Recorder
Polaroid DVD recorder need to re-set up can't see menu
I need to access the set up menu on my polaroid DRA01601a dvd recorder. I cannot see the menu because the signal is somehow messed up. how can I fix this?
  • 21 Answers
If you're using a SCART lead, bin it and get a new one, this seems to work best in most cases
Hope this helps
Alen Boardman
Posted on Feb 13, 2009
How to enter disc menu for finalizing dvd-r on philips dvdr3330H
The Disc Settings menu is accessed from the Disc Index Picture screen (so it's not as easily accessed as on other brands of DVD recorders). When you first put a recorded disc in the device, you'll see this index screen. At this point you need to press the UP arrow on the remote repeatedly until the disc content menu appears. This is a screen with the disc name, amount of recording time used and the date of the first recording. Then press the Right arrow button to get to the Disc Settings menu. Use the Down Arrow to reach the line that reads Finalise Disc. Then press OK and then press OK a second time to confirm the action.
The documentation for the DVDR3330H is available from Philips here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=hu&ctn=DVDR3330H/02 . See page 52 for the screen captures. The Finalise steps are on page 53.
I hope this helps.
Aug 19, 2012 | Philips DVDR3330H DVD Player/HDD Recorder
Dvd recorder
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
I accidentally set my Sony RDR-HX720 remote control setting to DVD 1 while I was reconfiguring various settings on it, and found out to my horror that the damn remote effectively died! - with no way to...
while pressing 'ENTER' on your remote, press and hold down the number '3' key for approx 4 seconds and then it should work.
the same process goes for 'DVD 1' and 'DVD 2' depending on the remote setting on the recorder.
there is no need to point the remote at the recorder when doing the above as it is only the remote itself that is being programmed.
hope this helps.
Jun 11, 2010 | Sony RDR-HX925 (250 GB) DVD Recorder / HDD...
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
I have the polaroid dra-01601a dvd/hdd audio
First of all with all do respect I do not have the polaroid drm 2001G. I have as I exprest in my letter to you the polaroid dra 01601A. The problem i had was an audio problem and i simply rechecked all my connections and found that I needed and extra set for HDMI plugs on my TV.
Jan 03, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid dra-01601a hdd to dvd recording
You will have to split the title and record on more than one DVD. The default speed is SP, that is 2 hours of recording. If you want to record longer programs, go into setup and change the default record speed to one of the other settings, for example: SP+ which is 2 1/2 hours or one of the other longer record settings. This DVD burner will only record at the same speed as you recorded to the hard drive. You can also edit out the commercials by using segment. Go to the title you want, press the right arrow, scroll down and select segment. When you want to start your edit, press enter. when you want to stop the edit, press enter again. You can use your right arrow to skip forward 30 seconds and your left arrow to skip back 10 seconds if you went too far when editing. You will see where your edits are on the screen by the darker color. Do this through the whole program. When you record to DVD, the commercials will not be recorded. Hope this helps you.
May 01, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Dvd skips right to movie's bonus features and not to the dvd menu. Push dvd menu button, i get previews. How do I set this tv dvd combo to just start like a normal dvd player?
The device needed a firmware update which polaroid mails you. WARNING!! I had to wait 2 hours on hold to talk to someone to get this disk mailed to me.
Mar 23, 2009 | Polaroid TDX-01930B 19 in. LCD HDTV
Vertical flipping
I bet you put it into PAL mode, the European standard. I believe that you can reset to factory default using the menu and it should be okay. If you cannot read and navigate the menu tree, then I think that if you hold the power button on after you start up, it will reset itself. I have not checked the doc to make sure of the last.
You can also get display problems if you pick the Y/R/G component setting in the menu. It is designed for connecting to a high definition using 3 different cables, one for each color. It only supplies vertical on one of those cables, and the TV just doesn't know what to do without the vertical blank signal from 'somewhere'.
Again, a menu setting.
tom
Dec 05, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Recording from the hard drive
you have to choos the sp mode which is over 2 hours in recording. i noticed that after you set it in sp mode and you press the record button on the recorder panel more than once, the recording time changes.
Feb 25, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid DRM-2001G DVD Recorder/HDD Recorder Logo
171 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
