Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
New Cozy Enclosed Front Console 70,000. Pilote goes out, gas stay
After I light the heater the pilot goes out, but the main burner remains on. If I click the igniter the pilot will light back up without me having to press the gas knob down. This is a brand new gas valve on the unit.
    New Friend:
  • 49 Answers
Sorry wrong unit, the standard is if pilot goes out you are allowed 3 minutes before gas has to shut down, that's how it should be tested.
Posted on Apr 06, 2015
  • 59 Answers
Its not the valve you have a problem with the heat exchanger a baffle issue have to change.
Posted on Nov 24, 2010
Pilot light wont stay lit.
if you can re light unit all parts are good. if vented into a chimney or vent less than 3 feet out of roof can cause this.
Jan 07, 2014 | Cozy Enclosed Front Console Heater 70,000...
My heater will fire but after usually after 30 but then cuts out
could a bad high limit switch on the heat exchanger .
or most likly a flame proofing switch in burner
Dec 10, 2009 | Cozy Enclosed Front Console Heater 70,000...
Pilot won't stay lit I have changed the thermo coupler
Make sure the thermocouple is in the pilot flame,if it does not stay on after that,replace the regulator.
Nov 16, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Feb 02, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
When unit goes on, there is a slight odor of gas when the valve
Cozy cheapened their heaters awhile back doing away with the air shutter. Without the shutter, a little gas can seep out into the room before it ignites and cause an odor. As for the curing odor, can you see the pilot flame looking down from the top of the heater? The pilot should be well inside the exchanger out of view. If you can see it, fumes from the pilot are getting into the room causing an odor. I had to remove the plate that holds the pilot assembly and drill a new hole shifting the plate over where it belongs. It was poorly assembled at the factory. Hope this helps.
Cozy heater
That piece that fell out is probably the pilot orifice. It goes on the end of the pilot gas line when you screw it into the pilot assembly. Don't try to light the heater without the orifice. If your thermocouple is good and the pilot flame is set properly, the control valve could be bad. Be sure to hold the knob down for 60 seconds before releasing it.
Nov 08, 2008 | Cozy Enclosed Front Console Heater 70,000...
Cozy furnace
The pilot orifice could be dirty causing the pilot flame to be too small. Unscrew the pilot tube at the pilot assembly. The orifice is inside. Remove the orifice and blow it out with compressed air only. Reassemble and see if that fixes the problem. If the pilot flame is set too low, sometimes opening a door will cause a draft to blow out the pilot. If the thermocouple is good and the pilot flame is set properly, the control valve may be bad.
Oct 22, 2008 | Cozy Enclosed Front Console Heater 70,000...
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
195 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
