Question about Kenmore 24032\24036 Top Load Washer
Kenmore series 90 washer spins but the clothes are still very wet
The washer runs the complete cycles no problem. However, after is spins the clothes are still very wet. The machine does spin but not effectively, on any cycle.
  • 20 Answers
You probably need a new clutch (Whirlpool Washer Clutch Kit 285785 fits kenmore too) , or your gear case is shot.
Posted on Feb 13, 2009
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
Jan 21, 2010 | Kenmore 22422 Top Load Washer
My 90 series kenmore wount spin fast enough to get all the water out
Jan 16, 2010 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 Series: Clothes very wet after spin cycle
I do not have this kind of washer, but I had same problem with my washer and I found the drain trap was full not allowing washer to completely drain. Hope this helps, Good Luck!
Feb 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer will only spin with a couple of pieces of clothing in it, when I add more wet clothing it will not spin. If I take some cloths out it will then spin. When washer spins the water is...
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Nov 12, 2008 | Kenmore 15864/15862 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
490 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
