Question about RCA D52W135D 52 in. TV/DVD Combo
Lines of resolution
How many lines of resolution is this tv
Horizontal lines of resolution are 1097.
Posted on Apr 02, 2009
Black horizontal lines top and bottom
This is called "Letterbox" and is common among sources. There is nothing wrong with your TV. When a movie or TV show is filmed, the camera it is filmed on has a certain resolution. It also goes through alot of processing before it reaches your TV. Your TV also has what is called a "Native Resolution". If the output resolution of your DVD, or TV station is not the same as your TV's Native Resolution, the TV "scales" the image to fit on the TV, hence the black bars on the top and the bottom of the image.
Nov 10, 2012 | Televison & Video
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Green lines down length of screen on my samsung 40 inch LE40F8
The reason for the green lines are the resolution. I'm assuming you're TV is set at 1080i, not 720p or 1080p correct? What happens is the "i" stands for interlaced, meaning, your TV displays your images with scan-lines. The "p" stands for progressive, meaning, TV displays picture as a whole. You can not visibly see the scan lines when seeing 1080i, but certain TV programs are not outputting their show to the resolution you're at, which will cause you to have the green line up at the top of your TV. SOME TVs might let you adjust the settings to rid yourself of the scanline, but most consumer TVs will not let you without the maintenance code to protect your unit from over calibrating and braking your television. Hope this helps.
Mar 20, 2010 | Samsung LTN1535 15 in. HD-Ready LCD...
What is the screen resolution for this set - Insignia NS-27RTV
Standard definition is 480. This TV has 500 lines of resolution. Detailed specifications can be found in the owner's manual, under the Support tab.
Jan 28, 2010 | Insignia NS-27RTV 27" TV
I HAVE THE TV AS A COMPUTER MONITOR AND THE RESOLUTION IS WRONG. IF I TRY TO MAKE THE RESOLUTION DIFFERENT THE SCREEN TURNS BLUE AND I CANT SEE ANYTHING THE RESOLUTION ID 800 X 600 AND I CANT ACCESS SOME...
If you are trying to change your Graphic Card resolution try this.Right Cilck anywhere on your desktop screen,You should get a Display Menu Box.Click on properties and then settings.You can now slide the resolution bar to 1024 x 786 click apply then OK your resolution will change and ask if you want to keep this setting if you got a display click yes.Remember to make sure your TV supports this resolution.Good Luck.
Sep 11, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Horazontal line across the bottom of the screen
Have you seen a same problem when playing DVD? If yes, the main board got defected
Apr 30, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
32" sanyo model ds32224
picture 330 lines
video input 700 lines
16.9 full HD has 1080 resolution and this is for a ds 32224
Jan 28, 2009 | Sanyo DS32224 TV
I have a sony 32 inch xbr TV (myt first non analog). HOw do you change the resolution from 480i to 1080i. What is the difference between 1080i and 1080p Thanks for your help. Maria
The resolution can only be change on your resolution source (ie cable box, dvd, etc). On your cablebox go to menu/setting->audio/video->output resolutions->and here you can change the setting. The main difference between i and p is how the video is scanned. I is interlaced, meaning you get the odd lines of video, then the even lines, and the picture may flutter but its better for fast action. P is progressive giving all the lines of video at once, better for still images, but slower of some tvs.
Dec 06, 2008 | Televison & Video
Resolution
Horizontal resolution: 705 lines
This TV is NOT High Definition but the picture is as close to HD as you can get. It also has 1 S-Video and 1 Composite port which gives a GREAT picture! I have owned this TV for about 8 years and still love it!
Mar 22, 2008 | RCA F36648 36" TV
RCA D52W135D 52 in. TV/DVD Combo Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
