Question about iLO MP3 Player
My ilo is just weird Please help me
When i plug it in it shows up in the corner and goes in and out. it doesn't show up in my computer and it will not show up in windows media player 9,10 or 11 please help me.
    Problem Solver:
  • 15 Answers
Read the instructions carefully. using media player is not a drop and drag situation u have to jump through some hoops to make it work that way. it in the instructions. http://www.lenoxx.com/2005/mp3player/mp556.htm if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working.
Posted on Aug 27, 2007
When i turn it on it just shows the ILO symbal and flashes
Hello.
In order to fix Your iLO Mp3 Player please follow these steps:
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
    Download the Firmware.
  3. Click Open to initiate the download.
  4. Double click on the ILO or Siren folder icon. There will be 14 icons.
  5. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
    Then click Run - this will open the Install Wizard.
  6. The Install Wizard has the instructions on the screen as you go through it.
    Once the firmware has installed, please click the Start menu, then Programs.
  7. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
Additional Tip: The player itself requires a lot of power while flashing the firmware. We suggest disconnecting all USB devices from the computer except the MP3 player and mouse; you can reconnect your keyboard once the firmware has been flashed.
Good Luck.
Nov 03, 2009 | iLO (2 GB) MP3 Player
ILO MP-556 MP3/WMA player
Revised iLo instructions for Windows Media Player 11:
Connect the iLo to the computer
In Windows Media Player 11, Run the mouse over the Sync tab
Click the little black arrow that appears underneath the Sync tab
Select More Options
Click the Devices Tab
Highlight the iLo
Click Properties
Uncheck box, "Create Folder Hierarchy on Device"
Download the firmware file at: https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip
then proceed with the rest of the directions
-Tha Mp3 Doctor
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connectedâ€
. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Jan 10, 2009 | iLO MP3 Player
Just stopped working
-Tha Mp3 Doctor
Sep 27, 2008 | iLO (2 GB) MP3 Player
Cannot download
Make sure the lock/hold is not engaged
-Tha Mp3 Doctor
Sep 25, 2008 | iLO (2 GB) MP3 Player
Will not turn on
Check the batteries, when you plug in to computer, does it comes on and stay?
Sep 01, 2007 | iLO (2 GB) MP3 Player
Mp3 player won't play
your ILO has somehow lost its file structure. look for a tiny pinhole to reset the device. if none, then remove batteries to attempt reset. if still no songs, then firmware upgrade if possible or copy file structure (using windows) from a friend's ILO.
Jun 08, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player and memory/files
You need to run chkdsk on the player. Plug it into your computer using the usb cord. Go to Start, Run, and type in chkdsk f: (or whatever drive your ilo shows up as). You'll get an option to repair the corrupted files. This worked for my ilo which had the same problem.
Mar 06, 2007 | iLO (2 GB) MP3 Player
Incorrect Format Please Reformat the Player
  3. Download the correct Firmware
    1. Click here to download the ILO 116 Firmware
  4. Click Open to initiate the download
  5. Double click on the ILO or Siren folder icon. There will be 14 icons.
  6. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
  7. Then click Run - this will open the Install Wizard.
  8. The Install Wizard has the instructions on the screen as you go through it.
  9. Once the firmware has installed, please click the Start menu, then Programs.
  10. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
Nov 28, 2006 | iLO (2 GB) MP3 Player
59 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
