Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Ultimate Care Dryer not heating
I've checked to see if there's excessive lint but no such luck. Is there a pilot light I might need to light or do I assume that the heating element is dead?
  • Anonymous Feb 16, 2009
    i have the same problem with my whirlpool gas dryer and i just replaced all my duct work and dryer vent so i no there isnt any lint cloged what else can it be
  • rotorx7tt May 11, 2010
    is it gas or electric? check your outlet to make sure both 120 volt leads are hot,also check breaker or fuse box.  if its gas, make sure your not out of gas!
  • 116 Answers
SOURCE: lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Posted on Mar 15, 2007
Master_Tech
  • 770 Answers
SOURCE: getting no heat in my whirlpool gold ultimate care 2 dryer
It sounds like you blew a Thermal fuse on the heating element open the back unplug and on the right side you will see towards the top of the heating element 2 red wires check with a metter to see if good also pull the wires off the element at the bottom to check it let me know
Posted on May 11, 2008
huuum
  • 750 Answers
SOURCE: Where is the pilot light on the Whirlpool Ultimate Care II Dryer?
Hello gigiknoll
Welcome to Fixya
My name is Huum,
This model should be electronic ignition and does not use a pilot light.
The igniter may be faulty.or the gas module may be faulty.
Pilots are a thing of the past!
This requires a tech to test it with equipment.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
  • 360 Answers
SOURCE: I need to find out how old is my Whirlpool Washer Ultimate Care 2
The copyright on the owners manual is 2003.
Here is a -->link<-- to download the manual if you would like.
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 10, 2009
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
No heat. all sencors in back including element check good and have been replaced but still no heat.
I'm sure you've cleaned your lint filter, but you also need to make sure there is no lint blocking the silver dryer hose. Mine gets plugged at the exit from the house and once I remove large amounts of lint, I have heat again. Also, if it's a gas dryer, is your pilot light lit?
May 04, 2011 | Whirlpool Dryers
My dryer is a ultimate care heavy duty super capacity runs fine but it wont heat up so it don't dry. Does it have a pilot or something i need to replace?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 20, 2011 | Whirlpool Dryers
The dryer appears to be overheating. The top of the dryer housing get hot while drying a load of cloths. More than normal. Checked dryer vent, lint catch (clean) and exhaust hose and all appears clear.
Excess lint can also cause a dryer to get too hot. Again, you should check the filter and the vent for lint. Clean them if needed. Another thing that could cause a dryer to get too hot is a bad blower. This would need to be replaced if damaged. You should also, never use white plastic vent. This can cause your dryer to overheat and also be a fire hazard.
If you are not already a repairman, there will be some problems that arise that you cannot fix. The idea is to know what to look for and to fix whatever problems you can. This way, you don't purchase a new one or call a repairman unless it's necessary. When making repairs, always unplug your clothes dryer for safety. If parts are needed, make sure you have your manufacturer and serial number with you before going shopping. This will help ensure that you buy the right parts and save you another trip to the store. Most of us are intimidated at the thought of dryer repair. Just keep in mind that a lot of common dryer problems are simple (excess lint) and can be fixed by anyoneIf the dryer heats when the Fabric Care/Temperature switch is set to AIR FLUFF (No Heat), check the following:
-HARNESS/CONNECTION
-HEATER RELAY
-FABRIC CARE SWITCH
-EVEN HEAT CONTROL
Procedure:
1. Perform the Fabric Care/Temperature Switch Test
2. Set the following configuration:
Door- must be closed
Fabric Care/Temperature switch- AIR FLUFF
Timer- TIMED DRY
3. Press the PUSH TO START switch
a. Check voltage on Heater Relay. If P3-1 to P3-2 is 0VDC, replace the Heater Relay
b. If P3-2 is 48VDC, replace the Even Heat control.
Dec 05, 2010 | Whirlpool WED8300S Dryer
Whirlpool Dryer LGR6611LQ0 will not heat up
there isn't a pilot you have an electroic ignitor in there part number 279311.there also is a sensor,gas coils and the gas valve,you need a meter to read them out,you said you checked the breaker and cleaned lint out ,is it dead?read out the thermal fuse first part number 3392519 located on blower wheel housing,unplug the dryer before you do anything and pull off one of the wires on thermal fuse then read it out hope this helps
Mar 22, 2009 | Whirlpool LGR6611L Gas Dryer
How To Open Bottom of Dryer
Take the back cover off and there is a compartment that hook to the hose, with the right tools you can pull the compartment out and clean it to include other parts showing. hope I helped allittle.
Mar 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II dryer will not dry clothes
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hello gigiknoll
Welcome to Fixya
My name is Huum,
Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II dryer not heating up
I have the same problem. Any luck?
May 19, 2008 | Dryers
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Lint trap
Mar 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
426 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
