Car died put a new battery in it did not hold a charge replaced second battery good for a day car is not charging the battery took alternatater out tested good twice battery is still losing charge
SOURCE: 1990 Mercury Grand Marquis- charging system failing.
Have you checked the positive connection from battery to starter? this connection has another feed that runs the rest of the car. Its either loose or corroded. Take battery terminals off and soak in baking soda, water and 2 drops of dishwashing detergent. If any corrosion is present this mixture will foam and remove your corrosion.
Its odd that car dies Are you sure you do not have a dead cell in the battery?
SOURCE: 1990 mercury marquis the alternater won't charge.
You may need to have the battery tested. If the battery is no good the alternator won't charge it. Check the belt also, make sure it's sized right and not overly worn or slipping. Hope this helps.
SOURCE: i have a 1999 grand
If the engine light is flashing then it has a severe misfire, have the engine light scanned and it will tell you which is the misfiring cylinder/s. I would advise you to replace the spark plugs also
Its seems voltage regulator issue.Get the vehicles charging system inspected. How
to inspect Vehicles Alternator? http://repairhelpcenter.blogspot.com/2011/11/how-to-inspect-vehicles-alternator.html --------- How
to Test Vehicles Alternator? http://repairhelpcenter.blogspot.com/2011/11/how-to-test-vehicles-alternator.html ------------- How
to Service Vehicles Alternator? http://repairhelpcenter.blogspot.com/2011/11/how-to-service-vehicles-alternator.html ------------ How
to Replace Alternator? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-alternator.html --------------- How
to monitor Vehicles charging system? http://repairhelpcenter.blogspot.com/2011/11/how-to-monitor-vehicles-charging-system.html ------------- Car
Alternator making noise? http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html -------------- Car
Alternator Working Intermittently? http://repairhelpcenter.blogspot.com/2011/12/car-alternator-working-intermittently.html ----------- Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition coil or
injectors getting cracked or dirty and needs to be cleaned. To
confirm the problem, the basic troubleshooting is required. From
start to end troubleshooting these problems I suggest you
to check the help link below and follow its procedure: ----- Mostly
all types of car no start problems are discussed here with solutions:--- CAR
NO START: ENGINE NOT TURNING OVER: http://alltypesofpartsreplacing.blogspot.com/2012/11/car-no-start-engine-not-turning-over.html --------- These will help. Thanks.
To troubleshoot these issue i suggest you few helpful links with solutions:---Click the link below:----
