Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Color fade on phillips 9p6034
I have a great picture but my color seems to be fading. doesthe coolant need changed?
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. Thiscolor fade on phillips 9p6034 - 2c07611.pngn problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
TV set aftcolor fade on phillips 9p6034 - 2c07611.pngange
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 13, 2009
    Novelist:
  • 184 Answers
How old is the TV? If its seven years or more, its likely that the coolant has turned into toxic waste. The problem now is that of parts availability. Looks like Philips may exit the consumer electronics business.
michtech
I have a faded picture on my Magnovox 55 inch
You can get the service manual at
www.servicemanuals.vstore.ca
If the color are dim you most likely need the phillips coolant kit also available there which contains the CD with instructions.
Jan 01, 2010 | Televison & Video
Picture faded model number is fp4620w103
This sounds like the coolant fluid needs to be changed - the coolant turns milky after awhile and you'll get a dull image.
Google TV repair world . com and look for philips/magnavox coolant replacement:
PHILLIPS CRT Coolant Replacement Kit This is the complete coolant kit for Phillips CRT rear projection televisions. Kit contains 48oz of top quality High purity optical grade coolant with complete detailed instructions produced in clear easy to understand terms with detailed photos and illustrations that takes you through the process step by step safely dischargeing the CRTs and eliminating the need for complete realigning proceedures.Restores the vibrant colors and focus issues commonly associated with coolant that needs replacement
Oct 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a 60" Philips 9P6044 C104 rear projection tv. The color seems to be getting weak and the colors seem to blend together. We think we may need new bulbs, but we dont know how to change them out. Is it...
its actually the collant in the CRts that makes the picture appear dim with colors being faded and hard to focus. You can get the CRT coolant kit at the following link which contains the coolant for all three CRTs and the CD with instructions on how to replace the coolant.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Jun 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color!
the dull and faded color could mean you need to change the coolant.
you could also try and adjust your convergence.
Jun 11, 2009 | Akai PTH5498 54" Rear Projection...
The color seems to be fading. NOt a clear picture.
Likely the picture tubes are getting weak from old age. Not much you can do about this.
Mar 30, 2009 | Televison & Video
Color and brightnes fading
the most likely cause is the coolant needs to be replaced in the CRTs. Very common problem. You can get the Phillips CRT coolant kit at the following link which contains the coolant and step by step instructions. Its listed under the repair kit category.
Mar 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture is fuzzy and color seems faded
Sounds like your coolant in the tubes need to be repalced. This is a common problem as the set gets older. Check with www.TvRepairKits.com for the supplies and instruction guide.
Dec 09, 2008 | Philips 46PP9302 46" Rear Projection...
Screen not crisp. words are blurry and colors are faded .
you need to replace the coolant in the cRts. You can get the coolant replacement kit at the following link under the repair kit category. Its called phillips CRT coolant replacement kit. It contains all the coolant you need and the step by step proceedur on cd with pictures so you can do the job yourself. Heres the link.
Aug 10, 2008 | Philips 6P4830W 48" Rear Projection...
Philips Magnavox 9P6034C 60... Problem
You need to change the coolant in the CRts ( picture tubes) you can get the Phillips coolant replacment kit at the following link with the coolant and the instruction CD with step by step instructions on how to do the replacment with pictures. Its listed under the repair kit category. Heres the link.
Aug 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
118 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
