Question about Canon Pixma iP6600D InkJet Photo Printer
I had a paper jam and now everytime I print there are lines
I had a paper jam and now whenever I print there are lines through the words and it will only print some of the stuff on the paper but not all of it. I have pressed on the printer the clean button which didnt fix anything so I went to press the deep cleaning and it came up with the error code 5100.....the same happened when I printed out the allignment sheet after the first page printed the same code came up again. Any ideas?
  • 4,041 Answers
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Everytime i print something in a label sized setting it always cuts into short
Before printing try using print preview first and adjust yur settings from there. Or go into control panel select printers and reset to default settings, restart your computer and try again. Good luck.
Sep 09, 2012 | Canon IP2700 Inkjet Printer
Paper jam always.
Helo have you tried to check on the driving gears it but try to call your technician to check on it otherwise you may spoil your printer
Jun 16, 2017 | HP PSC 1610 All-In-One InkJet Printer
Says there is a paper jam everytime i try to print
Hello
Check within your paper feeder rollers there might be something stuck inside it like paper clips, coins or anything small and solid. If you can find way to open the printer without braking it, that would be nice.
Hope this helps.
Jan 12, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Get Paper Jam everytime I print
its general problem with commen soln. just put the all pages properly & neatly in ur printer & turn on ur printer whenever u required & after finishing ur printing process turn off it everytime.Also dont give the fake printing commands it also affect ur printing process.
Dont turn off ur printer while process is running. its main reason of paper jam.
Aug 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
Print cartridge cradle cannot move & theirs no paper jam.
Kindly check inside if there are mechanical problems. Something stuff that blocks the cartridge...dirt for example...
May 12, 2009 | Office Equipment & Supplies
Smearing my printouts
Possible that the printhead got affected when it jammed the paper.
Take all the cartridges out and put them all back into the printer. Let it charge like it normally does.
Print a nozzle check pattern if you see any gaps or breaks or any missing lines on the pattern, clean the printhead.
May 02, 2009 | Epson Stylus NX400 InkJet Printer
HP LaserJet 4700N
paper jam on tray 1. How to open the back part of the printer.
Oct 17, 2008 | HP LaserJet 4700N Printer
Shortened header
Sounds like a pickup roller problem, try cleaning that, it is the main roller at the center at the bottom near the paper tray, think where would the paper go. that is where it is
Oct 07, 2008 | Samsung CLP 300 Laser Printer
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
HP 1610 - Skipping Lines when printing w/carriage return
You are lucky you can print ANYTHING! My unit has NEVER worked (3 years) due to a hardware defect of HP. I downloaded patches, cleaned/replaced cartridges, etc.
Spoke to HP last nite-Was told printer was junk-they don't carry it or any parts to fix it anymore!! I was told to replace it!
Apr 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
107 people viewed this question
old marine
old marine
