Question about Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca
Aperture and Shutter Speed for the Nikon Coolpix s550
How do I adjust the number of the shutter speed/aperature of my camera? Is it under Scenes? Do i chose the modes? I actually want to use a certain speed or number.
  • Anonymous Mar 10, 2009
    Same problem.....shutter speed too slow. I am missing some great pics of my daughters because of this. Any suggestions?
  • SRJ7128 Mar 30, 2009
    I DONT KNOW HOW TO ADJUST MY SHUTTER PEED AND APERTURE EITHER!
Go to the shooting menu and then press the ISO sensitivity option
Posted on Feb 22, 2009
I looked at page 100 and made the adjustment. Outside pictures are still too hot. Ideas?
check the properties of a recent picture.....check the shutter speed, aperture.....ISO.....use lower ISO and high aperture or change them according to the light conditions
Oct 04, 2014 | Nikon Coolpix 885 Digital Camera
How to adjest shutter speed of nikon p90
In the P, S, and M modes, turn the command dial on the back of the camera. In the A mode, turning the command dial changes the aperture and the camera will change the shutter speed to compensate.
In the point&shoot modes the camera will set the shutter speed on its own.
Apr 27, 2012 | Nikon COOLPIX P90 Digital Camera
The S and M modes on the dial..show black images when taking a pic; any idea why?
I'd say you're severely underexposing. The M mode is for manual exposure. This means you're responsible for setting the appropriate shutter speed and aperture. The aperture controls how much light passes through the lens, the shutter speed controls how long that light hits the sensor. The two of them have to be adjusted properly to suit the amount of light hitting the subject. If the lens doesn't admit enough light and/or the shutter is opened for too short an amount of time, not enough light gets to the sensor and you get a black image.
The S mode is for shutter priority. This lets you set the shutter speed and the camera automatically adjusts the lens aperture for correct exposure. However, the lens has a maximum aperture beyond which it cannot open. If the shutter speed is too fast, again not enough light gets through the lens and you get a black image.
Since you didn't specify the model of your Nikon camera, I can't tell you exactly how to adjust the shutter speed and aperture. If you can't find the procedure in your manual, please feel free to reply to this post, specifying the model.
Feb 24, 2011 | Nikon Cameras
How do I change the shutter speed on a Nikon EM film SLR
The EM doesn't really have a manual shutter speed setting. It does have a Bulb setting for long exposures and a 1/90 second manual for flash, but otherwise the camera automatically sets the shutter speed to go with the currently selected aperture.
Normally you would set the aperture and let the camera set the shutter speed. You can adjust the shutter speed by pressing the exposure compensation button for +2 stops. You can also adjust the exposure by changing the ASA/ISO setting.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_em/nikon_em.htm
Jun 29, 2010 | Nikon EM 35mm SLR Camera
How do I adjust the aperture on the Nikon D5000 DSLR camera?
It depends on the exposure mode.
In Program mode (P), turn the command dial and the camera will shift the exposure by changing both the aperture and the shutter speed.
In Aperture-priority mode (A), turn the command dial and the camera will adjust the shutter speed to suit.
In Manual mode (M), hold the aperture button and turn the command dial.
If you're using a lens with an aperture ring, turn it to its smallest aperture (largest f/number) and lock it.
Feb 17, 2010 | Nikon D5000 Digital Camera
How can i slow the shutter speed on my Nikon Coolpix L100
technically you cant, the l100 is an all automatic camera, meaning you cant manually set the ISO, aperture, or shutter speed... a good way to slow the shutterspeed would be to autofocus on something similar but darker, then keep that focus for the origonal shot...
Dec 24, 2009 | Nikon COOLPIX L100 Digital Camera
How do i read a light meter on a Nikon N55? i see the f stop but i dont see the shuter speed, how do i adjust and how do i know its right?
Your camera is either fully automatic or fully manual. In addition it has shutter priority and aperture priority semi-automatic functions. With shutter prior. you pick the shutter speed you prefer and the camera will adjust the aperture. With Aperture prior it works the other way around. The exposure will be always the optimum (decided by the camera program).
You can adjust these automatics with the program dial.
Oct 28, 2009 | Nikon N55 35mm Film Camera
Digiscope
Hey timpo,
I would definitely use some kind of remote release since even the smallest amount of camera shake (pressing the shutter button) can cause blurry images in high magnification images. At the type of magnifications usually involved in digiscopeing the depth of field of your images will be greatly reduced and you will need to set the camera to a smaller aperture than usual, which should result in slower shutter speeds. I would definitely have the camera set to manual exposure mode so you can control both the shutter and the aperture although aperture priority should also work well. I would not set the camera to a higher iso since you will lose quality, and since I am assuming you are using a tripod slow shutter speeds should not be an issue. Any movement by the subject will blur the subject if you are using slow shutter speeds so if this becomes an issue you can set the camera to a wider aperture at the loss of depth of field to achieve a faster shutter speed. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 27, 2008 | Nikon Coolpix 5700 Digital Camera
External Flash
The aperature error is due to the fact that the lens in not a constant aperature design. The settings on the LCD are assuming you are at full wide angle setting. As this lens moves towards telephoto, the aperature changes about 2/3 of an f-stop due to the mechanical movement of the lens elements. So a manual setting of f4.0 at full telephoto will be more llike f5.0 in reality. It is too bad Epson could not make the mechanical aperature adjust to compensate, but every nice feature costs something. I have not had any issue with the shutter speed changing. One guess is that the camera has shutter speed/aperature combinations that it can't achieve due to mechanical limitations, so it chooses the available combination. Another is that it wasn't in manual mode, but rather aperature priority mode and the final adjustments changed the speed.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca Logo
1,035 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
