Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Can't get oven to heat over 175
This is a new slide in range tried to use bake , conv bake, probe bake and will not go to temp only heats to 175
  • Jenn-Air Master
  • 1,218 Answers
Not very specific in your statement, so I'll venture a few things to look at.
Check to see that it is getting the correct power (voltage). Could be wired wrong.
Several things could be causing this. If electric, wrong or low voltage. If it is new, just out of the box, then it could have received some shipping damage. Delivery trucks never hit potholes (Ha Ha). A simple wire could be loose or probe knocked out of position.
Something is telling the controls that the desired temp is reached and the unit it cycling off.
This may or may not be a simple fix.
Posted on Feb 13, 2009
When I press the Bake Button it only heats to 175 degrees instead of 350. Using the temp up Button the maximum heat is 260 degrees. How do I return to the proper settings?
Hello Jim;
My name is Peter. I am a retired Sears Home Services/A&E Factory Service field service appliance technician.
The information in regards to your model number does not match any known range. The model number is on a metal plate on the face of your oven when you open the door.
There are several components that effect the control of your oven temperature.
1.) Is your oven electric or gas?
2.) If electric do you see any sparking on the heating element?
3.) Does your broiler work?
I really do not know what you have. Give me the model number or call me @ 443-306-1362 and I will try to help you.
Peter Goodwin
Glen Burnie, MD
Jan 30, 2015 | Kitchen Ranges
Oven turns on but wont heat up
Hello Jacob J - Try resetting the range by unplugging it or flipping the breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective and oven does not bake or broil contact a professional to move forward accurately. Range could possibly be experiencing an issue with a wiring failure, EOC, sensor probe and/or faulty elements which would need further diagnosing.
Dec 14, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not baking.
Sounds like the flame failure device is not working . or heat probe is out of position
Aug 07, 2017 | Frigidaire FGF337 Dual Fuel (Electric and...
I have a whirlpool range mod rf368lxpq o replaed probe and panel still very slow to come to temp. pre heat goes to about 200 deg and then veryy slow to come up to temp and hold temp
It sounds like one of the elements are not working. There should be a concealed element in the bottom of the oven and a 'bake assist' element at the top iether seperate from the grill element or as a dual element assembly. Both of these elements should heat on bake function (not the grill element though), check for heat from both by turning bake on and feeling for heat from top and bottom. The oven requires heat from bot to get up to and maintain temp.
Hope this helps
Dec 02, 2009 | Kitchen Ranges
I have a Maytag model MER5775QAW free standing range. When you press "bake" and then set the temp. and press "bake" again the numbers instantly climb to the set temp and the buzzer beeps showing oven at...
Unplug the range open the control panel to access the electronic oven control. Unplug the wires and wait 5 minutes. Replace all wires on the control and turn the power back on.
If this does not reset your oven control it must be replaced.
Your ERC(clock) is bad and must be replaced.
Nov 09, 2009 | Maytag MER5775Q Electric Kitchen Range
My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
Sep 21, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven on RF263LXTT2 does not maintain a constant heat. Oven heats, but doesn't seem to continue heating at a constant heat during the baking process. Both coils heat up during the preheat. Seems like once...
The problem looks like a faulty electronic control. When you select baking, the broiling element should not come up.
Before replacing control assembly, test the temp probe located inside the cavity, check the wiring harness to temp probe and elements, and ensure that the fan is working if the oven is fan assisted.
Sep 18, 2009 | Whirlpool Ovens
Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Jul 13, 2009 | Kenmore Kitchen Ranges
GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
111 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
