Question about LG WM-2077C Front Load Washer
Washer shaking the washer shakes so much during the rinse cycle that the whole house shakes and does not matter how big or small the load is
  • 20 Answers
First make sure the shipping bolts were removed from the machine, then make sure it is level, then if it still shakes, take your fist and hit it on your head... jk, if you have it on a wood floor, or your floor isnt 100% sturdy, you cant do anything about it besides using anti vibration pads. they wont do that much tho.
Posted on Feb 13, 2009
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
It shakes so violently, it knocked 2 holes in the wall. During the spin cycle, it also turned completely around backwards!! It's so loud it practically shakes the whole house.
take bottom panel off,check the shocks,if it is making loud noise it's probably spider gear,if you keep using it the boot could rip off and you'll have a flood,get rid of washer it will cost as much to fix washer that you could buy a new one but that's up to you to decide
Nov 06, 2009 | Frigidaire FTF2140F Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Washer making noise during spinning cycle.
why is my ge front load washer making a rumbling noise
Jan 06, 2009 | GE Washing Machines
New front load washer shakes my whole house
remove the shipping material...read install instructions that came with owners maneul
Dec 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
90 Series Top Load Washer shakes during spin cycle
The Guide Plate underneath is out of alignment,, You might have to call me on this one. The only reason I am sure of this is because when my delivery guys would deliver a direct drive washer such as your, sometimes when the machine is laid down to far on its side, it gets out of alignment. Easy fix,, Just hard to explain.
Mar 24, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
LG WM-2077C Front Load Washer Logo
578 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
