Question about Vizio GV42L 42 in. LCD Television
Start up settings.
I began set up on my TV without reading manual later to find out that If i have a set-top box i am to skip the antenna/cable sellection. So I selected cable and know cant get channels to change. thank u
    New Friend:
  • 56 Answers
Go to main menu and do a rescan for channel.
Posted on Feb 17, 2009
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
How to program channels
go into settings and then rescan for channels
May 07, 2015 | Televison & Video
Tv wont tne in to ch9 why iam getting all the other channels
If you are using an antenna to receive broadcast TV you may have to rescan to add channel 9 back into the TV's channel list. If this does not work, it may be seasonal or a weak signal from your channel 9 broadcaster. I use a signal booster on my antenna (purchased at Radio Shack..)
Dec 10, 2014 | Samsung Pn64d8000 64-inch 1080p 600hz 3d...
I don't have signal on my tv and there are no program's to watch as they are all blank. Is just a brand new tv I bought like 2 days ago
What make and model of TV do you have? What is your signal source (OTA (indoor or outdoor antenna), cable, satellite)? How is the TV connected to the source?
The model is important since some "TVs" are actually only monitors and do not have tuners. Then you need to connect to a set top box to watch anything.
Assuming the TV has an ATSC (digital) tuner for OTA, check that your antenna is pointed in the correct direction for the stations in your area. Use antennaweb.org or tvfool.com to identify the direction. Antennaweb assumes an external antenna and gives a very conservative list of stations. TVfool tells you the type of antenna needed to get any station (assuming no trees or tall buildings that might block the signal). Depending on your TV, you will need to enter the menu in order to correctly set the incoming signal type and scan for channels. Digital signals are either enough for the tuner to interpret or not available. If your signal is split between several TVs you may need an amplifier to get enough signal. Sometimes, the amplifier may fail and filter out all stations in certain frequencies. (Older TVs often only had a NTSC tuner; there are very few NTSC stations still broadcasting. They are low-power and thus you may not be able to watch them if they are far away.)
If you have cable without a box, which type of cable signal is coming in? Digital cable is QAM and not all TVs have a clearQAM tuner (that reads the unencrypted signal).
If you are using a set top box, make sure to set the TV to the correct input (HDMI, component video, composite video, coax and the correct number if there are multiple inputs). Make sure that the box is also on. If the set top box requires the TV to be set to a specific channel (3,4,60), make sure to go to that channel.
I hope this helps.
(For the US, the digital OTA tuner is ATSC and QAM for cable. In other countries, different signal formats are used.)
Oct 22, 2012 | Televison & Video
Cannot get it to change the channel to recieve cable from the cable box. it says it is on channel 2.1
If you are using the channel up and down buttons, sometimes it will skip channels. Try manually putting in 03 using the remote to change to channel 3. Also make sure that in the TV menu you have the TV set to Cable instead of Antenna.
Jan 13, 2011 | Sharp LC-19SB14U 19 in. LCD TV
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
Attenna hook up
Yes, This set does not have a digital tuner built in. All over the air signals are now digital. This set will work without a converter if hooked up to standard cable,DVD,VCR or Video game console. If you purchase a DVD with a digital tuner built in you can skip the converter box and hook your HDTV antenna directly to it.
May 06, 2010 | Symphonic ST4919 19" TV
"Failed to receive broadcast"
On your TV remote,press "INPUT".It is hard to find,but it should be there.Select"TV" and press"ENTER" button.I believe it is on the top of the list.On some cable boxes you have to select channel 3 and use the cable box remote to change channels.Also,make sure your TV antenna setting is set to "Cable" from the "Air/Cable"(Antenna setting).You will have to read your manual to find out how to get to this menu.After that do a "Ch Search"[Channel search].This automatically searches for all available channels and stores them. It will take some time.You will see the channel numbers as it does it's search.This is done so when you press channel up and down keys it will only go to next channel available and not to one with no signal.Hope this is of some help.
Feb 19, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Everything on the TV works EXCEPT live TV.
Please clarify a few things. Are you using cable TV, satellite TV or a TV antenna? If cable, are you using a set top box (and is it powered on) or does the TV convert the cable info. If satellite, is the set top box powered on? If off the air (antenna TV), can the TV receive the new digital signals and if not, do you have a digital converter box between the antenna and the TV?
Jun 04, 2009 | Toshiba REGZA 47HL167 TV
Vizio GV42L 42 in. LCD Television Logo
89 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
