Question about Canon imageRUNNER 5000 Copier
Clc 5000 dont pull paper
My clc 5000 dont take paper from nowhere
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    Is it IR-5000 or a CLC - 5000. Be a little specific about what & where?
    Problem Solver:
  • 10 Answers
Check paper guide if it is not check you program
Posted on Aug 06, 2009
Eroor en la canno 5000 004 000
This is the error code for the thermistors not reading the fuser temperature correctly. You can reset the error once and if it comes back the thermistors mostly have to be replaced. Look to see if there is some paper blocking the thermisors getting a good reading. Press the additional Function key and the press the 2 and 8 key at the same time and then the additional function key again. This will get you into the service mode. Press copier, then function, then CLEAR, then ERR, then OK. Turn of the power and power back on. All should be good again. If this error comes back or any other ones with single digits then a tech will have to reair it.
Sep 21, 2011 | Canon CLC 5000 Copier
I lost my keys for canon clc 5000. can i start it in any other way
Open Right cover (3 screws) -
to close the 2 wires to the switch - key
state without - not closed
the key is turned - closed
Sep 07, 2011 | Canon CLC 5000 Copier
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
Paper jams
first try to clean paper feed rollers in cass.
Jul 27, 2010 | Canon CLC 1120 Color Copier
Runshort of clc 5000 consumbles like drum,blade,greed, toner can you help procuring ?
try to locate Katun dealer, its not genuine parts, but they arent bad. www.katun.com.
Hope that helped
Jul 05, 2010 | Canon CLC 5000 Copier
How to print envelopes on clc 5000
this not necessary a software because this machine have got that funcion on setting to bypass and casset
Feb 10, 2009 | Canon CLC 5000 Copier
The copied paper is half soiled with fuser oil.
Pull out fuser unit and remove the top. ( let machine cool down, VERY HOT!!) does the fuser web need replacing ( looks like a white paper towel roll) it has fuse oil on it. is it overflowing?? try cleaning, do not spill on floor it is very slippery and hard to clean up.
Jan 22, 2009 | Canon CLC 1000 Color Copier
Canon clc 1180 error code 071-0007
k you may have several problems you may take some canned air and blow out the connectors on the tx unit and the inside frame particularly the connectors on the lower right rear frame wall .. when you pull out the tx unit you may also want to turn the two cam gears on the lower left rear frame all the way clockwise then slide unit in
Jan 10, 2009 | Canon CLC 1180 Copier
I have problem in CLC 5000 machine. There are some errors. Error
clean or replace your pattern reader also turn image off in service mode this is only a temp solution and you can get miss regristation later on
Dec 27, 2008 | Canon CLC 5000 Copier
Canon Copier CLC 900 problems color management settings
you can buy manuals for little money from canon.com. Cheers Thomas
Nov 27, 2008 | Canon CLC-700 Copier
Canon imageRUNNER 5000 Copier Logo
74 people viewed this question
old marine
old marine
