Question about Whirlpool LXR9445JT Top Load Washer
Whirlpool LXR9445JQ having trouble with spin cycles.
Just replaced the dogs on the agitator, and was having troubles with the lid switch so bypassed and wired together. Washing machine completes the wash cycle, then goes to rinse and the water does drain out but the tub will only spin if I give it a push first, then it spins fine. With the last spin cycle, unless the tub is a really light load it never gets going fast enough to get all the water out of the clothes and again need to 'start' the cycle.
Any help would be appreciated. Thanks. More then glad to check if there are anymore hints, or troubleshooting required.
  • verybig_axe Feb 12, 2009
    When there is no load in the tub, it spins out fine (well with a push at the beginning of the cycle). Think it might be the Direct Drive coupling. Going to pull it apart and see. When I know I'll post. Thanks again for the help
  • verybig_axe Feb 13, 2009
    So on further inspection the direct drive coupling is fine. Ran the machine with just a cup of Vinegar to clean it out and it completed the whole cycle fine. Wash, Rinse, Drain and Spin. Just seems to be when there is any type of load that the problem arises. Maybe there is something caught in between the tub and wash basket? Can't see anything.
    President:
  • 1,902 Answers
Check the motor and make sure that the RPMs are high enough, Also check the tension on the belt
Posted on Feb 12, 2009
Kenmore model 110, stock 22811 fill with water but does not agitate
Try the machine in all the available cycles. If it only agitates in one or more, but not in all cycles, the timer is bad.
Here are a few other things to check: First, make sure the lid switch is working. Generally, if you press down on the switch lever with a small screwdriver or similar tool, and it clicks as you press and release it, it's probably OK. If you hear the motor running, the switch is good. Also if the machine spins, the switch is good.
Next, try to rotate the agitator by hand. If you can, either the ratchet "dogs" are worn and need to be replaced, or the drive splines are worn, and the agitator needs to be replaced.
Next, look under the machine, right in the middle, up front. If you see shavings that look like black rubber, or white plastic, under the motor, The motor coupling has broken or disintegrated, and needs to be replaced.
Finally, if all the above check out OK, the problem is inside the gear case (transmission).
Dec 23, 2010 | Kenmore 24032\24036 Top Load Washer
Spin cycle
Does it agitate?
Does it spin by hand?
Does it agitate if you advance the timer?
Could be the lid switch (#1).
Could be a broken motor/pump coupling.
Could be the timer.
Look under the washer for bits of black rubber (indicating the coupling insert has failed.
If the coupling is in place, next, bypass the lid switch temporarily to see if you can trick the unit to think the door is closed (safety mechanism)
if the lid switch is bypassed, the coupling is good, the timer is faulty.
All items in this answer can be found at repairclinic.com and enter your model # in the box.
If you hear the motor trying to spin - the most common problem in this direct drive unit is the rubber coupling element and broken coupling teeth.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 15, 2010 | Whirlpool Washing Machines
Does not spin or agitate kenmore top load mod.22832 year 2001
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
WHIRLPOOL MANUFACTURED WASHERS USE A 110. PREFIX. THE NUMBER YOU PROVIDED IS A STOCK NUMBER, NOT THE MODEL NUMBER.
See the following for where to find the model number on most machines.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=21
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Mar 23, 2010 | Kenmore Washing Machines
WASHER FILL, NO PROBLEMS AGITATING, WHEN TIME
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
Following is an illustrated description of how to remove the cabinet on Kenmore / Whirlpool top load direct drive washers.
Since it won't drain, the problem points to the lid switch. You already have the cabinet off so replacing the switch isn't too difficult.
The Sears site has the Sears (and probably Whirlpool) part number.
Oct 08, 2009 | Washing Machines
Motor just humm's when put on spin. Doen's seen to
Assuming that this is the basic Kenmore / Whirlpool top load, direct drive, neutral drain two piece agitator model.
There is a Sears repair parts site:
Enter your model number and a list of major sub-components will come up.
Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) or spinning the solution points to a couple of places.
1. The motor coupler may be broken. This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
Remove the cabinet and inspect the coupler. Following is a good description of how to replace it if necessary.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The coupler consists of three pieces. Two plastic pieces with three prongs each that fit on the shafts of the motor and transmission and a rubber piece with six holes that the plastic prongs fit into.
If the prongs are broken off, or the rubber piece is broken, the motor cannot apply power to the transmission for agitating or spinning.
If the coupler is OK, the problem points to the motor or transmission.
If you move the timer to the spin cycle, and the machine drains the water , the motor is probably OK.
I'd also check the Lid Switch that prevents the motor from turning in the spin cycle.
Following is a Whirlpool PDf on how top load, direct drive washers work with a troubleshooting guide and description of how to bypass the LID Switch.
Oct 02, 2009 | Kenmore Washing Machines
Whirlpool direct drive top loader will not spin
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LSR8433K Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
No agitate and no spin
ok,,you need agitator dogs ,,the top auger move booth direction,,worn agitator dogs,,,i need you to fill unit on smal use a poy or bucket i have to know if this washes,,,onthejob
Jan 16, 2009 | Whirlpool Washing Machines
Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine trouble
it sounds as if your lid switch is out of position. in the past depending on the model i have taped a penny or two to the top of the switch so the plunger makes contact
Jul 21, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LXR9445JT Top Load Washer Logo
206 people viewed this question
Dan Webster
Dan Webster
Sal De
