Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Door Won't Open
Hotpoint Aquarius WD440, our door won't open. is there a release catch under the lid? Really need the clothes out, and have tried cutting power, leaving it for an hour, starting cycle again, but door still won't open.
    Scholar:
  • 99 Answers
This is joyce
Have you tried to go to ge.com and download your documenton. your book. put in your model # and this will give you some info on why the door wont open. their is a reason.
let me know if you need any help, if you cant find out why, let me know and I will research it a little more and see if I can get you some help, but you may have to call a technician out to fix problem.
thanks
joyce
Posted on Feb 13, 2009
Door lockedshut with washing inside
Disconnect from the power socket. Leave for 5 minutes.
If still not opening, ensure it is not plugged in and remove the lid by unscrewing fixings at the back and sliding forward.
Catch can then be released from inside casing by sliding lock bar.
Will need new door interlock assembly.
Jul 05, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Wd440
Catch sticking.....place the palm of your hand on the door frame just by the catch and give a sharp ,firm push.
May 25, 2013 | Hotpoint Aquarius WD640 Front Load...
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
HELP! Very urgent! I have a Hotpoint Aquarius WD440 washer/dryer and the door handle has broken off. My clothes are stuck inside and I need them by tonight. How do I get the latch to open. I know I need to...
Slide a thin knife from 3 o clock door position against the frame to push the locking latch pin towards your left, only about a centimeter and the door would then release
Dec 21, 2012 | Washing Machines
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
I cannot open the door on my Hotpoint Aquarius wt740 after it finished a wash. Door handle is floppy and door light is off.
it sounds like you have a broken door handle Disconnect power before doing anthing remove lid , what you will need to do is usining a screw driver or somthing simular look down to where the catch is (you may need a tourch) and look carefully you should be able to to the door catch mechanisim from inside you will need to mimic the action of the door handel but using a screw driver it a bit fiddley but can be done there is no grate force needed and it the catch will only need to move a bout 3-8 mm to open
Jan 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do i open the door on hotpoint WD440, latch is broken?
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Door on hotpoint aquarious wont open at end of wash cycle...in spite of door light OFF. Have checked drain off plug..its OK!
door catch is faulty unplug machine take off lid put hand down to door switch and pull back to open door replace handle kit
Jun 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius w.machine door catch broken.
easy way is to cut or break away the handle so the start of the door peg is exposed and use a screwdriver on the peg to lever it out
Aug 30, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
1,019 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
