Question about Kenmore 24032\24036 Top Load Washer
Water does not stop when in spin cycle,# 23032
Modle 23032 top load,it all works good but when in spin cycle the water never cuts off.
  • bakerash Feb 25, 2009
    I have the same problem with the Kenmore # 23032...water does not stop when in spin cycle. It is 7 yrs old. I read the solution about checking 3 things but what am I looking for when I check each one? Thanks!
    President:
  • 1,902 Answers
Check three things. Check your Water inlet valve with a multimeter, check your timer and you water sensor. All can be found behind the knobs by removing two side screws and 4 screws in the back of the unit. If this helped please rate. Thank you
Posted on Feb 12, 2009
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer does not spin out during the spin cycle. Everything else is working properly.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 14, 2011 | Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Will agitate but won't spin leaving the water in the tub.
the transmission may have been damaged during the runaway.to much movement can cause it harm that is why they come with a shipping rod in them.
Aug 08, 2009 | Kenmore 22422 Top Load Washer
Kenmore top load washer making loud noise in spin
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 02, 2009 | Kenmore 22422 Top Load Washer
On our Fisher and Paykel, the spin cycle does not
ok guest you can set a fisher and paykel machine to skip one rince cycle so as to save water,
Feb 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Jan 06, 2008 | Admiral AW22 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
