IR2870 HANGUP I HAVE IR2870 MACHINE AND WHEN I PRESS THE COPY BUTTON THEN SCANNER SCAN THE PAGE AND RTURN OT IS POSITION BUT AFTER THIS MACHINE IS HANG UP BUT SCREE IS WORKING AND COPY PRESS BUTTON IS NOT WORKED AND PAGE IS ALSO HANGUP IN MACHINE AND MACHINE DOES NOT CANCEL THE COPY AFTER PRESSING THE CANCEL BUTTON AND THERE IS NO CODE SHOWN BY MACHINE. 1. SCREEN IS WORKING 2- PAGE IS HANGUP 3. COPY BUTTON DOES NOT WORKED 4. MACHINE DOES NOT CANCEL THE COPY 5. THERE IS NO CODE SHOW BY MACHINE,
    Top Expert:
  • Office Equip... Master
  • 63,995 Answers
Contact the manufacturer thru their website . I see no make listed
Posted on Feb 29, 2016
SOURCE:
Dinoza
  • 112 Answers
SOURCE: HP All-in-one will not scan
I think I have the solution for you (after facing similar problem). Try installing the drivers and then go to my computer right click on the HP and select "Scan using wizard". My HP is able to scan using this method although I still can't scan using the button on the printer so if you don't mind clicking the mouse instead of the printer's button you should be fine. Let me know if it worked. Cheers, D.
Posted on Jul 14, 2007
  • 1684 Answers
SOURCE: HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
  • 295 Answers
SOURCE: my kodak scanner won't scan but will print pictures
connect ur printer to ur computer and then try to scan any document or plug in any memory card and then press scan .it will ask u to save the file after scanning, save it on computer. ur issue will be resolved
Posted on Jul 27, 2009
  • 4 Answers
SOURCE: Unable to use scanner
you may need to reinstall your drivers for your scanner
Posted on Aug 10, 2009
kerguney
  • 577 Answers
SOURCE: CANON MX 320 SCANNER PROBLEM
You need to control the scanner thru your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" on your PC..thats it..
Posted on Jan 15, 2010
Copy on HP Laserjet 200 Color MFP
If you just want a single copy of the document, place the page face down on the scanner glass or face up in the document feeder. Then press Copy on the all-in-one (for the M276 this is on the touch screen). If you need to adjust the image quality/size or paper size, press Settings. Then press Image Adjust or scroll down and touch Paper. When done adjusting any setting, press OK. Then press Black or Color depending on your source page.
If you want to scan to a computer first, you'll need to make sure that the full software is installed on that computer. Then launch a scan from the computer before using the touch screen's scan button. You need to set up the default scan options before the scan button works. (There is a monitor program "hears" the button and it needs to know the scan defaults and destinations to launch the appropriate parts of the software.)
Note: many all-ones will not work if there is a problem with the print system.
I hope this helps.
Mar 18, 2014 | HP Color LaserJet Pro 200 M275nw
HP Deskjet f4435 will print, but won't scan. Orange light blinks
When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please help...you may need to reinstall your ..
Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
Xerox C20 displaying "Scanner Locked" message. Won't copy.
  1. Press the power switch to the OFF (O) position. The power switch is located on the lower, left side of the machine.
  2. Pull the scan lock switch toward the front of the machine to unlock the Scanner.
    NOTE: The scan lock switch is located on the bottom of the Scanner Module. Make sure the scan lock is completely free. It sometimes hangs at the halfway point.
  3. Press the power switch to the ON (|) position. A 'Warming Up, Please Wait' message will be displayed on the Display Screen. Warm up time is less than 40 seconds from power ON and less than 25 seconds from the Power Saver mode.
Aug 30, 2010 | Xerox CopyCentre C20 Black and White...
I want to operate the scanner for this machine
Usually, you need to print a test page: go to start, settings, find printers and faxes and open it. You will see your printer. Right click on the printer and you will see a menu. Open Properties. Find General- there is a "print test page" button. Click on it. When the test page is printed, you will see some pictures: those are the steps you need to take to make your scanner work. Basically, all you need to do is put the test page in your scanner (as indicated) and press scan. The scanner will then do an alignment and you will be able to scan.
Apr 05, 2010 | HP PSC 2410 All-In-One InkJet Printer
How to copy
just insert the paper in feeder and press the copy buton in fronpanel it will copy the page.
Dec 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
How do i use my scanner?
If you want Photocopy by using scanner just put your original document on scanner and press copy option.
here is two copy black and color for black copy and color copy
If you want to scan from printer to PC. Install scanner software from your driver CD and use scan sofware.
Remember that you can use only page for scan. can not use book. because this is not flatbed scanner.
Thanks
Sk. Abdus Sabur
Nov 29, 2009 | HP Officejet 4315v All-In-One InkJet...
How do i scan a doucment for print dont have a manual 5600 seris
1. Open the scanner cover.
2. Load or place that piece of paper on the glass bed.
3. Close the cover.
4. Press the COPY button.
No "COPY" button?
PRESS THE "OK" button or the "SET' button and it will copy like a xerox machine"
Nov 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Ricoh Aficio 2090 Printing config question
You have to scan each one individually. The machine can scan them into a pdf file. Press user tools button. Press the scanner button and check the file format settings for individual files. Select PDF if needed.
Nov 13, 2008 | Office Equipment & Supplies
PSC 1410 prints the test page every time I turn it on.
hi,
if alignment page comes out don't press copy just put on scanner and press scan to align the new cartridge..
hope this will you..
rey
Nov 03, 2008 | HP PSC 1410 All-In-One InkJet Printer
jasbo
jasbo
Ekse
Marvin
Marvin
