Question about Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V
Pump will not work in high speed
I have Jacuzzi spa pump and it is a 2 speed, low speed work fine in the heat mode but high speed will not cut on. Does anyone have any ideas?
  • deljal Feb 17, 2009
    This spa is very old, 25 years. It does not have any boards or read outs. I did find were the wire marked high speed goes to a relay but was not sure how to volt/amp check it to see if this is the problem. Julie
  • deljal Feb 19, 2009
    Control box in brown, it only has wire going to what I believe is a relay. It does have a plastic tube which I can blow and be blower to come on and off but not the pump.
Clean the relay contacts on the board. Cut the power, ofcourse. Also, try switching the hot wire on the low side of the pump to the high side to rule out the pump.
Posted on Jun 08, 2009
    Problem Solver:
  • 11 Answers
Only three posible problems. High is out on pump. Spa side control is out. Control box relay that runs high pump is out.Does upper controls(spa side) read out a code? Kirk
Posted on Feb 17, 2009
  • kirk toulouse Feb 18, 2009
    Jacuzzi system is analog then. Is control box blue in color? Does relay have just wires on it, or also a plastic tube hooked to it? Kirk
Spa overheats because no circulation during heating process
As I'm sure you know the low speed is the filtration & heating cycle.
If you've checked the terminals on the board and on the pump & there's nothing wrong. Use a voltmeter to test if each leg is getting the right voltage. If not its likely the motor is bad.
Nov 11, 2012 | Pool & Spa
Balboa 52502 val 5m7
have you cleaned your filter recently. Sound like there may be a low flow error in low speed
either that or the start capacitor on your pump is bad and the pump will not come on in low speed unless you first give it a boost in high speed
anytime you ask for heat with insufficient flow there will be an error message
Jun 21, 2012 | Balboa Instruments Pool & Spa
Hydroquip eco-3 series 3 blinking lights
possible bad 2 speed relay
Oct 27, 2017 | Pool & Spa
My pump works on low speed but not high speed
these are a bear to work on.. there are start switches inside of the motor, and will break if you even look at them wrong.(fragile) you can try compressed air to blow out the trash that might be in the switch..or unhook power cord of the motor from the motherboard and remove the pump and motor from the spa , bring it to your local pool pump moor repair guy with free testing have it tested. if removing wires from motor YOU MUST REINSTALL THEM EXACTLY AS THEY CAME OFF ! OR YOU WILL BURN UP THE expensive 2 speed motor .. jay Florida
Dec 20, 2011 | Pool & Spa
I have a Balboa R574 control and heater on a Jacuzzi Spa. The motor starts and runs fine on low speed, but trips the exterior GFI after about three minutes running on high pump. The pump and motor were...
Understand that this information isbeing provided as-is and without warranty or guarantee. As with allelectrical components and devices, all work should be performed by a licensedspa or pool technician. Serious injury or death can occur if a component isimproperly repaired or installed. This islikely an issue with the GFCI breaker not being able to handle the load or aproblem with the high speed of the pump.
You can find answers to common spa orbath problems online at http://www.balboadirect.com/support.aspx Hope that helps!
May 23, 2011 | Balboa Instruments Duplex Digital Panel 2...
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Laser II: Problem with the Heater/filter setting. The jets come on when it's on this setting. When I turn it to Filter setting it's fine..when I turn it off the jets come back on What gives?
The jets will run while in the filtration / heating mode. If the spa is in the middle of the filtration cycle, the jets will stay on until the cycle time runs out. So, if the spa jets are on during this time, they are on for the full duration, 2-6 hours every 12. You can cycle the jet button to high, but when you try to turn them off, they will just go back on low.
Jan 23, 2010 | Jacuzzi Cyget In Ground Pool Pumps
When my jacuzzi spa is in high speed, it pulsates. any ideas?
You're impeller is bent, The cost to replace the impeller is about $75.00 if you do the work!
Jun 08, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pump stops running on high speed
You have a magnetek motor and it is overheating and cycling its thermal overload. A local electric motor repair shop may be able to fix it however it will likely need to be replaced. It is to costly to repair the motor if the damage is in the windings.
Assuming at that low a horsepower it is 115V, the likely replacement motor is a catalog #BN37. We sell it for $157. You are usually better off replacing the seal when you replace the motor and most Jacuzzi pumps are either a 200 or 1000. They should be around $5.
Jun 07, 2009 | Jacuzzi Pool & Spa
Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V Logo
1,183 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
