Question about Epson Stylus CX9400 Photo Printer
Epson cx9400 won't receive a fax
I can fax but think something is amiss in the settings--can't receive a fax. the phone rings and rings--doesn't connect when someone is trying to send us one... afraid to mess around without advice--
  • SKF8 Mar 04, 2009
    Well, I just spent eons on this, driving me nuts, and finally found that my DRD (Distinctive Ring Detection) was set to Double instead of Single.  So, if you are trying to receive faxes on a line with only one ring, ie. "normal", make sure it's set up for a "Single" ring in the DRD area.  Because of my mistake it didn't recognize the 'normal', 'single' ring.  Great machine, my fault.
    Fax Settings
    Communication
    DRD (hit arrow to right)
    Select "Single"
    (and try the link below for more ideas if that doesn't work)
    http://www.fixya.com/support/t639569-cha...
Basti
  • 1447 Answers
SOURCE: cannot send out faxes
Directly from the wall, phone line should be connected to to Line port at the back of the printer and answering machine should be connected to EXT. port from the back of the printer. Make sure on the fax setting on the printer that you have all the info already ( ur number and stuffs), communication setting on the printer, drd set to all, ecm to off, v.34 to off, rings to answer 6 and dial tone detection to off. and answering machine distinctive ring pattern should be set to 4rings.
And since you are using DSL make sure that line from wall should have a filter then connect it to LINE port at the back of printer...
Posted on Apr 06, 2008
  • 77 Answers
SOURCE: Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
Posted on May 23, 2007
  • 6 Answers
SOURCE: EPSON CX9400
also see http://www.fixya.com/support/t639569-change_baud_rate_9600_epson_cx9400fax
Posted on Aug 11, 2008
SOURCE: epson cx9400 fax
How do I send a Fax
Posted on Sep 13, 2008
localwonder
  • 6784 Answers
SOURCE: Epson cx9400 printer/scanner/fax
Follow these steps to print a nozzle check:
  1. Load letter-size paper in the sheet feeder.
  2. Press the cp_button_1.gif On button to turn on the Epson Stylus CX.
  3. Press the Setup button.
  4. Select Maintenance and press OK.
  5. Select Nozzle Check and press OK.
  7. Press the cp_button_6.gif Start button to print a nozzle check.
  8. Shown below are some examples of what the nozzle check may look like.
Posted on Mar 01, 2009
Epson Stylus CX5700f I have just setup fax. I am having problems receiving faxes and telephone calls
You need to do two more steps.
1. contact the phone company about distitive ring. This will have a different ring for incoming faxes.
2. set the fax up for distitive ring once the phone company sets you up. This will cause the fax only to answer when another fax is calling, due to the distictive ring set up.
Feb 14, 2012 | Epson Stylus CX5700F All-In-One InkJet...
Epson 630 workforce won't fax to some numbers.
followed edger allans remedy and now faxes that where not answering before now are. i think mostly because i had it set to, 1 ring to answer and i changed to 6. thanks.
Feb 07, 2012 | Epson WorkForce 600 All-In-One InkJet...
Canot recieve fax
Try these settings ::>>
1.) Press Setup
2.) Select Fax Settings, then press OK
3.) Select Communication, then press OK
< under communication try these settings >
> DRD should be all
> ECM should be off
> V.34 should be off
> Rings to answer ( if you have an answering machine?
or a voice mail service either virtual or physical.,
check how many rings does it have before it picks up )
set your printers rings to answer about 2 rings higher than these devices.
> Auto answer on the control Panel of the printer should be on / enabled
Note ::>> If still cannot receive a fax? try to disconnect your voice mail or
answering machine to the line to Isolate Issue whether printer cannot receive
a fax or the said devices is having an issue with the printers fax
receiving capability.
Mar 28, 2009 | Epson Stylus CX9400 Photo Printer
Can't send or receive
fax machines are analog devices and will not work reliably on a digital phone line.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Fax function not working
Make sure that the phone line is plugged in directly to the line port of your printer. Please check on the diagram below.
Just to isolate the issue do not plugin yet the answering machine or voice mail as of the moment. So basically the phoneline setup is from the walljack going to the printer.
We need to adjust the settings first.
Change
DRD > all
ECM > off
V.34 > off
Rings to answer > 4
Dial tone detection > on
Note: make sure the auto answer is turned on.
Then you can test to send/receive fax
Oct 14, 2008 | Epson Stylus CX9400 Photo Printer
EPSON CX9400
Did you hit the Auto Answer button? The green light next to it should be on.
Jul 30, 2008 | Epson Stylus CX9400 Photo Printer
Cannot send out faxes
Apr 03, 2008 | Epson Stylus CX9400 Photo Printer
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Help
no.you need dial tone to send faxes. dsl is for computer use.
wg
Feb 10, 2008 | Epson Stylus CX9400 Photo Printer
Cx9400fax
Epson Quick Guide is incorrect.
Not sure of your exact situation but .........
Your answering machine MUST be connected directly to the output of your CX9400 and you can't use an answering machine with multiple "mailboxes". Set your answering machine to 4 and your CX9400 to 5/6 rings. Epson "Technical Support" has no clue of this problem .... yet.
The machine routes the call to your answering machine, it it's an incoming FAX and the answering machine starts the CX9400 will recognize the incoming transmit signal, turn on the FAX function, and disconnect your answering machine.
You may need to adjust the CX9400 rings setting based upon the duration of your answering machines announce message (longer message = greater number)
Jan 28, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Photo Printer Logo
1,186 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
