Question about Marantz SR-5000
FOR MARANTZ SR5000 RECEIVER
I du not how to hoock up the wires in the back of it.
  • 86 Answers
For the RCA cables there color coated RED and WHITE, for example ur hooking up a cdplayer 2 ur unit, cd player output, Red = Right, White = left
the cables go to the cd input on the back of the unit, same as for selections DVD,AUX,an so on some mite have a yellow witch would be Video
and for the speakers, some are black an red, some are clear an has a white strip that would be the negitive wire, red is postive black is negitive those are the color codes for the terminal on the speaker outputs, hope thats what ur asking
hope it helps
Posted on Feb 13, 2009
Receiver turns off after it has played for a few minutes. I reset the light and it will run again for a while and then turns off.
There are a few possible causes:
1. Your receiver is broken.
2. One of your speakers has a short in it.
To tell which, disconnect all your speakers at the back of your Marantz, and turn it on. Does it stay on? If yes, then check your speaker wires and speakers one at a time for normal volume...
Dec 11, 2015 | Marantz Sr 6001 Receiver
How do I connect CD player to marantz NR1504 with phono leads
Connect the cd audio out to the line in or cd in on the marantz
Nov 25, 2014 | Marantz NR1504 5.1-channel Home Theater...
I have a Marantz SR5000 receiver that stopped responding to the remote control. seems like the remote is working properly. The receiver also works fine besides the fact that it stopped responding to the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Aug 22, 2011 | Marantz SR-5000
I have had my Marantz Sr5000 for some time now and I just noticed the rear speakers have stopped working. Everything else seems to be working fine. When I run the test tone I get a tone from everything but...
First of all if you have not made any connection changes in the system prior to loosing the sound try these steps.
Go into the system menu and in speaker configuration see if somebody has given the rear ( surround ) speakers as none. If not just exchange the front and back speakers to confirm if its a speaker failure . If not you will need professional help to fix a damaged surround amplifier.
Mar 08, 2011 | Marantz SR-5000
My marantz SR 7400 suddenly shuts down or goes into protect mode shows code CKPWR5
Most likely you have a speaker short, you need to check the ohms on each speaker disconnected from receiver if they are 8 ohms they should be close to that on the meter no more than a 1 and half ohm varience to what the speaker ohms says on the back. If they are ok you need to disconnect speaker wire from receiver and check for a short in the wire by connecting ohm meter leads to ends of the speaker wire you should get no reading if the wire is good. If this is all good you have a bad output transister in your receiver, but i dout this is the case because these transisters normally short to ground and blow a fuse. Hope you solve your problem good luck
May 24, 2010 | Marantz SR-7400 Receiver
Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
I am trying to use the 12 volt trigger on my new Integra preamp to turn on my old Marantz MA700's. How do I do it?
at the back of Marantz receiver try to find and output connection of 12 volts,if not you must open your receiver then connect the 12 volts at the output voltage transformer..
hope this may help
DONT FORGET TO RATE:
Regards,
VOTIT
Jul 29, 2008 | Marantz Audio Players & Recorders
Marantz SR5000 Protect mode
The Marantz SR5000 and others of it's make, design type, and year group are prone to this problem. Many such units can be reset by pressing a sequence of three buttons with sporadic results... the SR5000; however, does not provide any such option. If the "Auto protect" mode comes "on" then you know it's not a simple power supply "fuse" problem that can be fixed for a dollar by opening the case and replacing the glass fuse with one of the same rating value that is stenciled on to the power supply circuit board. (Easier than trying to read the old fuse.) If you can get the schematics and know a bit about replacing electronics parts using a low-power soldering iron, then you might want to take a shot at fixing it; otherwise, it's time for recycling. (Tip: Look for discolouration on a part on a circuit board first, this indicates overheating and a possible short. Then trace the schematic circuit for the "Auto Protect" circuit to diagnose which integrated circuits is at fault.) Typically, it costs more to fix it in a commercial shop than it's worth as someone has to pay the cost of benchtime diagnostics... the repair part is fast once the faulty parts are discovered. There are free sources on-line of the service guide for this receiver; however, downloading the plethora of rar files to assemble a complete manual is a challenge.
May 13, 2007 | Marantz SR-5000
Marantz SR-5000 Logo
240 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
