Question about Panasonic NN-S541 Microwave Oven
Panasonic NN-H264 1200...stops after 3 seconds
Panasonic NN-H264 1200...no matter what program or time is set. The microwave starts or tries to start for two to three seconds then the display clears and stops. There is power to the display and control pad. Model NN S541WF does the very same thing.
I found sufficient information elsewhere.
Posted on Feb 13, 2009
  • Joydeep Sengupta Mar 09, 2012
    Could you please share the solution? I am having the same problem. Thanks!
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I had the same problem it was the door switches.The metal the door switches mounts on was paper thin. When you closed the door the switches would flex to the right. This made the door hard to close and the switches would not work right . The microwave would time out after 3 seconds. I removed the cover with a star bit and a Phillips screwdriver. I bent the switches back perpendicular with the front of the oven. I then cut a notch in the end of a Popsickle stick . I then put the notch against the switches where a plastic alignment piece goes through them . The other end fits into the corner side of the frame after careful measurement for length. This keeps the thin metal that the switches are mounted on from bending outward. I then dip a Qtip in Vaseline and lube the two switch arms and the switches in the door frame. Be sure the rear end of Popsickle stick is square this way it wont fall out of place. Opening and closing the door will keep a slight pressure on the stick . My microware works perfect now for over a month so far. Its been 2 years now and still works perfect.
Posted on Sep 25, 2015
Could you please share the solution? I am having same problem.
Posted on Mar 09, 2012
Panasonic NN-F542BF 1300 watts microwave switches off after 3 seconds
It sounds like you were sold somebody else's problem, it could be a bad magnetron, cracked high voltage diode, and a shorted high voltage capacitor to name a few. I recommend a professional if you feel it is worth getting checked.
Mar 09, 2012 | Panasonic Microwave Ovens
My Panasonic microwave NN-C944S starts for 2-3 seconds, then stops. No message whatsoever. What could be the problem? Thanks.
this microwave has a history of this ,web search-panasonic nnt964sf, click on recall listing.I would contact company for reimbursment and notify the BBB
Oct 06, 2010 | Panasonic NN-T964SF Microwave Oven
I have a Panasonic microwave convection that runs for 2 or 3 seconds, then cuts off. It doesn't matter what setting or length of time you program into it, it will run a couple of seconds and shut down. Is...
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Sep 08, 2010 | Panasonic NN-C994S Convection/Microwave...
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Stops after 3 seconds - Panasonic NN-S252BF
may be magnetron spoiled or high voltage section problem,please check circuit andreplace damage parts...
Aug 14, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic NN-S541 Microwave Oven Logo
2,266 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
