Question about Kodak Advantix F620 Zoom APS Point and Shoot Camera
Dont take any pictures
When i turn camera ON, display starts flashing and nothing works even lens is closed! The film is inside in the beginig display shows 16 frames left(for a 2 sec) and then display starts flashing shows anything it can show at all...
Help me please to solve this problem!!! Thank you for any advise!!!
  • 1 more comment
  • gvsass Feb 14, 2009
    I've all ready try... No luck :(
    sorry but i cant open it, maybe it because the film is inside partly photographin...
  • gvsass Feb 15, 2009
    Ok, i rewind the film, and when i rewind it the screen flashing like it flashing in past, i get the film off the camera and it's behavior said "E" and than screen starts flashing again...
    Scholar:
  • 170 Answers
Change the batteries and try again.
Posted on Feb 14, 2009
  • Sujith Gopinath
    Sujith Gopinath Feb 14, 2009
    The open the film chamber a little bit in a dark room and close immediately.
Fuji Instax Mini 25 can't do anything!
hi,
most likely it's the motherboard spoil. bring it to nearest repair center to get it fix. mini 25 repair cost $55 to $65 SGD.
RT
May 02, 2013 | FUJIFILM Photography
My nikon d40 camera barely dropped on the carpet and now when i take the pictures they are all dark even with flash on. please help me
ok, lets try a few things...First, make sure the knobs, buttons, settings, etc have not moved from the drop or put them back where they belong if they did move. I would suggest doing a "Green button"
reset. Turn on your camera, press and hold the two buttons that have the "green" dot next to them, release them after you see the display flash( a few seconds). this resets the camera to the factory defaults on most adjustments, enough to get it working correctly if nothing is actually broken. Once you have done that, make sure the lens is properly mounted and locked in position. check the lens to see if you can focus and zoom it by hand, this will tell you if the lens is "basically" ok. we need to see if the aperture is closing down when the picture is taken. to do this, point the camera toward you so you can see inside the front end of the lens. you should be viewing the camera like it is in the picture in the top of this post, looking at the front. watch closely inside the lens and take a picture of yourself(without flash!!). you should have seen the aperture close down and then open back up. If you saw this then the camera is working the aperture correctly. if all that is working we need to check the speed and fstop settings of the camera. a quick way to do this is as follows. I'm assuming you know how to set your camera on Manual. Set the iso at 200, go outside, on a sunny day and take a meter reading off the grass in the lawn. the meter should read fairly close to 1/200 (1/250)with your aperture set at f16. If you get this reading then your meter is working ok. next set your camera on manual, and adjust the shutter speeds from slow to fast. take a picture at slow and see if the shutter opens and closes slowly, then take a shot at fast speed to see if the speed of the shutter is "following" your commands, we are looking to see that there is a noticeable difference between "real Slow" and Real fast". if so, now we know that the shutter is working properly. if any of these don't seem right you will need to dig deeper to find the problem or get it serviced. Hopefully the lens bumped out of position when it fell, that would be the easiest to fix, but, that is all i can think of for now. Good luck, Worm1855.
Jan 17, 2011 | Nikon D40x Digital Camera
Dont know how to get pictures
Well maybe making sure the battery is fully charged, remove the front lens cap if one is on camera, find the button to press to start to film and take aim at a thing to film that looks good, that's how most people get pictures.
May 24, 2010 | Optimus DV-3040 Flash Media Camcorder
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
I have a Kodak Easyshare model dx5430 digital camera (5mp). It has worked like a champ for years. Last night I was at an event when the image display went dark at picture 31. All preceding photos were able...
May 01, 2010 | Canon PowerShot A75 Digital Camera
I loaded the film but display window shows a flashing zero
Go ahead and try anyway. A ruined film is far cheaper than a useless camera or a professional repair. In any case, if the film hasn't loaded properly it will only be the first short length of film which is ruined. As this is a newly loaded film you haven't any risk of losing any undeveloped photos.
Auto spooling film systems are great when they work, but sometimes are a real pain and some cameras seem really picky about having a film leader of precisely the right length. See if you can engage the the film onto the spool manually.
May 14, 2009 | Canon Prima Super 105X - Point & Shoot /...
Nothing happens when I turn the camera on.
First would be to check your batteries. If they are good look inside the battery holder see if there is battery corrosion, if so it should go to Nikon for CLA.
Call Nikon Nikon Film 1-800-645-6687
Feb 18, 2009 | Nikon F100 with 28-80 and 70-300 lens 35mm...
Changing lens
Your Nikon is a SLR which stands for single lens reflex. The reflex part is the way the mirror that lets you look through the lens to frame the picture flips up to let the light go straight to the film. You can change the lens half way through the film roll because the mirror is down while you change the film and blocks light from getting to the film, just as it blocks the light until you push the shutter button. Have fun with your 'new' camera! I use an even older style Nikon FE2. I like my Nikon 55mm macro lens but your newer camera takes autofocus lenses so you'll need advice from someone else for that.
Oct 01, 2008 | Nikon F65 35mm SLR Camera
'Err' & 'E"
Is the film loaded correctly? Have you tried reloading it? Also is it flashing DX too? That would mean the film speed is not DX coded so you need to set the film speed manually.
Sep 23, 2008 | Nikon N80 35mm SLR Camera
Loaded film wrong??
I'm assuming you're not able to shoot pics. Its my best guess that the film just isn't getting loaded properly. Next time you attempt to load film there maybe a small red mark near the take spool (bottom edge where film goes) to indicate how far you need to pull the leader forward toward take up spool. I think the film isn't out quite far enough for the camera to do its auto load thing & when you close the back it goes thru its auto loading motions but the film just isn't getting loaded. Then close back & see what happens.
Apr 27, 2007 | Konica Minolta Maxxum QTsi with 35-80 lens...
Kodak Advantix F620 Zoom APS Point and Shoot Camera Logo
110 people viewed this question
Top Kodak Photography Experts
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
