Question about Canon MultiPASS F60 All-In-One InkJet Printer
Won't print - it has set for a period of time (months) without be
Being used. I changed cartridge but still not printing. Moves but no print on page.
    President:
  • 415 Answers
YIf it has set for a long period of time you may need to replace the ink cartridges to solve the problem
Posted on Feb 12, 2009
I've got a Dell Printer 962. Recently it was printing horizontal lines all the way down the page. Now it has stopped that and is showing an error message "right cartridge incorrect" and won't print. It...
Hi Sobek70,
Please check if the cartridge is not dried out.
It will get dried out if you have not used that cartridge for certain period of time.
Try to replace the color Cartridge.
Oct 17, 2013 | Computers & Internet
My HP Deskjet F380 will only print blank pages. There is plenty of ink left in both cartridges. I've been on the HP help site. It didn't help. It won't photocopy either. It printed the top part...
the body of text of the test page is black ink. From what you describe, the print heads are clogged. Most HPs use cartridges that have the head built in, but if not used for an externded period they can dry up and clog.
Try repeated head cleanings (10 or more) see if any change. If none, try new HP ink cartridges
Jul 12, 2011 | HP DeskJet F380 All-In-One Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
Dell 922, 4 yrs old, did not change color cartridge, now prints blue highlight over all images and text. Have clicked "clean t fix horiz streaks" and wiped head. No change. Help!
If the cartridge was left in it during an extended period of time (we'll say three months or longer) without use, it can damage the print head in a way that is irreparable. At four years old, unfortunately, it is probably cheaper to replace the printer than to have the head professionally repaired. Dry ink is the great enemy of inkjet printers.
If you clicked the cleaner multiple times with no luck, the only thing besides replacing the printer I would suggest would be to try another print cartridge. Unfortunately, if this isn't the problem you've just wasted whatever the cartridge costs. BUT if this unit directly touches the cartridge to the paper to print, it should repair the problem.
Jan 03, 2010 | Dell 922 All-In-One InkJet Printer
My Deskjet 3915 has gone over half a year without use and will not print. The paper is fed through and the ink cartridge moves back and forth, but no ink comes out. Any ideas?
You have committed the cardinal sin of inkjet printers, lack of use. The printer responds by letting the ink dry up in the feeder tubes and the printhead nozzels.
While it is possible to repair, time and dollars and cents (sense) say "Hey, it's time to buy a new printer!
Next time, if possible, print at least 1 page a couple of times a month. A pain, but it works.
Aug 03, 2009 | HP Deskjet 3915 InkJet Printer
HP printers - remove and check cartridge. (Use it or lose it)
There is no solution for HP Printers being used very lightly - meaning "not for months" etc.
As a result, if you are stuck in this predicament - an HP inkjet, that you only need every few months - I instead suggest you set a calendar entry for once a week or more and run a test page.
The printer will "hopefully" not dry out by being periodically used - and the ink "wasted" will result in a LONGER cartridge life than if you had to throw out a cartridge.
There is also a time period, or sensing of the cartridge, that results in a wasteful cleaning cycle in which it pumps ink "down the drain", and I'd like to know how often to test print to avoid that.
My solution to my most recent problem was to "give up" and throw a new (black) cartridge on it and take the barely-used one out.
Jul 07, 2009 | HP PSC 2410 All-In-One InkJet Printer
Print page on SCX4100- streaking lines
Clearly bad toner cartridge. After long periods of time, the cleaning blade dries out. This cleaning blade works just as the wiper blades of your car. When they wear or dry out, you get streaking water lines in the windshield. Most manufacturers print an expiration date on the consumables wichi you can check before purchasing. Also try not to stock more consumables than those you plan to use within 6 months.
Nov 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Hi, I haven't used my Canon S330 printer for some months, and when I plugged it in just now, it wouldn't print. I replaced both cartridges, and still no printing. The cartridge moves fairly quickly back...
in the print head there are hundreds of minute holes from where the ink of the cartridge comes out when you remove the head check whether the ink is coming from the holes in the head .if the ink is not coming the head may be dry and if the very less ink is coming then some of the holes are blocked. the ink has to come out from that holes for printing.
thanks.
Sep 18, 2008 | Office Equipment & Supplies
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Canon MultiPASS F60 All-In-One InkJet Printer Logo
79 people viewed this question
old marine
old marine
