Question about Canon PIXMA MP160 All-In-One InkJet Printer
How to change the ink for canon i350
The canon i350 flashes 4 orange blunks followed by a green blink and i have lost the manual of the printer, also i want to change the ink cartlidge but i do not know how to fix it
pls. can i find any help
    Novelist:
    Champion:
  • 201 Answers
Try This:
Here's the owners manual
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/I350-_E
Hope this helps
Dr. Geek MD
Posted on Feb 12, 2009
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon i350 printer won't print; alternates flashing green/orange.
Sounds like the printer head is clogged or damaged.
I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
Hope this helps.
Oct 25, 2009 | Canon Office Equipment & Supplies
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
After the power went off my printer doesn't print and is in a cycle of green and orange light. What can I do?
my printer says the waste ink tank is full, and the power lamp flashes alternately green and orange
Jun 30, 2009 | Canon i350 InkJet Printer
Canon i950 flashing orange green orange green
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Aug 22, 2008 | Canon i950 InkJet Photo Printer
Not printing - Flashing lights!!
If the following happens to your printer from canon's support page i found these:
"Issue: Power light (or Alarm and Power lights) alternate(s) between orange and green
Solution: The i350 may require repair
Unfortunately, the issue you describe seems to indicate that your product may require repair service. If you feel your product might require service, a Technical Support Representative will be happy to answer any questions you may have and explain the service options available to you. You can contact us through the email link or phone numbers listed below."
Nov 23, 2007 | Office Equipment & Supplies
Canon i350
http://startcopy.ru/repair/can_s_ip.htm
Nov 08, 2007 | Canon i350 InkJet Printer
Canon i350 printer waste ink tray full.
according to cannon the Waste ink ABORBER not tank is getting full. To clear this error press resume and print button. But this will only fix your problem if at all for a short time as this is not considered user replaceable part. You can contact canon on line at http://consumer.usa.canon.com Good luck
Apr 22, 2006 | Canon i350 InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
378 people viewed this question
old marine
old marine
