Question about Lavazza Espresso Point Capsule Machine
Coffee grounds in cup
We have had our machine for a couple years and just within last couple of weeks, when making coffee we get a lot of grounds in the coffee.
  • marketplaces Feb 12, 2009
    If there is a filter in our lavazza I don't know where it is. How do I get to it?
  • ashish13
    ashish13 May 11, 2010
    Did you try changing the filter ???
  • 131 Answers
This is caused by the water overflowing the filter. If you changed brands of filters, try going to a different filter that is not so heavy. If you haven't, the hole in the bottom of your filter basket might have built-up coffee in it, slowing the flow down. Try putting a sharp knife in the hole & turning it around to clean off any build-up.
Posted on Feb 12, 2009
Arter each couple od cups the tray has a lot of coffee groumds and must be cleaned.Why?
what exactly must be cleaned? you mean the tray for the used coffee grounds or other components?
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Grounds in cup
what is you primery foult what is the model does the coffee goes in the waist?
Sep 01, 2017 | Nespresso Coffee Makers & Espresso...
My Keurig/ Platinum coffee maker/ purchased 10/09 is running very slowly when making a cup of coffee. I have vinegar cleaned it as frequently as suggested by the manual and twice in the last 2 weeks w/ 0...
Hello, W/D here.
A lot of people have luck with clearing the needles to improve their Keurig's operation. Here's how:
Take an ordinary paper clip, and make it into an "L" with about 1" on the short side. Use the short side to probe up into the puncture needles on the top side of the K-cup, and the dispensing side as well. Frequently, grounds escape the K-cups and get trapped in the needles.
Best regards, --W/D--
Please feel free to rate this solution. Thanks.
Feb 05, 2011 | Keurig Platinum B70 Coffee Maker
My machine only brews 1/2 cup of coffee. I have de-scaled twice within the last week and I get a full cup of vinegar/water, but as soon as I put in a K-cup I only get 1/2 cup of coffee out. The first cup...
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Aug 15, 2009 | Keurig B60 Coffee Maker
Coffee crounds
The problem you are having is common when these units have been in use for a while. There is a sludge buildup preventing the brewed coffee from leaving the brewer soon enough. Straighten out a paper clip and use the wire to open up the blockage in the hole where the coffee would enter the coffee cup. You may have to go up from the bottom in order to do this thoroughly.
Feb 12, 2009 | Lavazza Espresso Point Capsule Machine
Saeco Incanto -- no coffee coming out
After I posted this I decided to descale the machine again, even though I'd just done it a couple of weeks ago. After descaling and rinsing I tried running water through the brew group by pressing the pre-ground button, then holding down the big cup button. Still no water, but then I turned the little knob on the coffee dispenser counterclockwise, about half a turn. It worked! I rinsed it well, then made a cup of delicious espresso.
Mar 01, 2008 | Saeco Incanto Classic Espresso Machine
Defective Coffee Maker
THE ON - OFF SWITCH STAYS ON(ON) POSITION. IT STILL WORKS BUT I HAVE TO UN PLUG IT TO SHUT IT OFF. DO YOU HAVE A PARTS DEPT WHERE I CAN JUST BUY THE SWITCH
Oct 17, 2007 | Mr. Coffee NLX5
Lavazza Espresso Point Capsule Machine Logo
66 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
