Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
Kelvinator F/Freezer not working. Not fuse
The inside light works but element not warming up and inside both fridge and freezer not cooling...? Thermostat does not click at all. Only 1-2 yrs old.
    Problem Solver:
  • 8 Answers
I had same problem and got the solution in part from this fixya site. (thank you). my fridge freezer bulb blew when I was cleaning out fridge because the back wall used to get iced up at least once a week. This was due to the door seal not fully sealing hence warm air getting in and causing the ice to form. Anyway, having replaced the fuse in the plug (and testing out the wall socket with another electrical appliance just to be sure that the mains power was working)and replacing the bulb, the fridge freezer still wouldnt work even though the light came on. Got a peplacement thermostat unit from local repair shop and fitted it myelf. I am not goo with this type of repair ususlly and generally if its electrical I dont do it but this time it was either spend £20.00 and possibly fix fridge or spend £300 replacing it. I photographed the connections from the thermostat BEFORE I removed any wires so that it would be put back together correctly. IT WORKED! If I can do this by myself then anybody who can physically use a screwdriver, can do it. there is only one screw to take out. The rest of the job is simply prising off the housing from the interior fridge wall and clicking it back int place again. simples.
Posted on Aug 08, 2009
    Problem Solver:
  • 16 Answers
Sounds like gas is out.Probably leaking Contact the dealer where you bought it,Should still have guarantee.Jan
Posted on Feb 13, 2009
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
How does the control panel work? low numbers warm etc?? I inherited my partners mothers fridge freezer, unfortunatly it didn't include the instrution book,I have had it running on number 2 but it seems to...
Typically the larger the number the colder the setting. Is there an arrow on the knob that points to the left or right that says "warmer" or "colder" I also question your comment "freeze too much" because this is a freezer only, it will not keep things "cool" if you turn it up enough. If you mean there is frost on everything that is humidity and not the freezers fault.
Jun 03, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Aug 09, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 | Freezers
Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Oct 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Refrigerator freezer
Hi bb
The warming of the fridge is not to worry thing and about the freezer you should do some defrosting work time and again .
this would help in defreezing a bit .
and if you want it to get less warm turn it off for a little time.
Feb 16, 2008 | Freezers
Freezers Logo
527 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
