Question about Home
Whirlpool bath starts,but water doesn't jet
Is there a way to "prime the pumps" to get my whirlpool to work?  The motor runs, but it does not circulate the water
    President:
  • 2,692 Answers
If that is what it needs and the pump impellor is actually working(turning) then filling the tube leading into the pump, until it take no more water, will prime the pump.
Posted on Feb 12, 2009
Kohler whirlpool type tub will not pump water out of its jets or take water into the intake. Pump appears to operate fine. Water does not want to move. Suggestions?
When a bath pump turns on but does not move any water it is usually because there is an Air Lock and needs to be released.Try this.
  • Fill the tub with water
  • Turn the pump on
  • Unthread the discharge pump union until water starts to squirt out
  • when this happens you should hear a big 'swoosh'
if the bath pump starts to discharge water through the jets then you have solved the problem.
Rod
us parts center
888-521-6183
Apr 05, 2013 | Kohler Home
Maxx jetted tub quit pumping water, pump motor just races.
When the bath pump runs and you get no water going through the jets in your bath Jet trim then the impeller has probably spun off the shaft of the motor.You will not know if this is the case until you take the bath pump out and remove the front cover of the bath pump and check the impeller.If this is the case it usually has to be replaced.
Rod
US Parts Center
888-521-6183
Feb 22, 2013 | Home
On my whirlpool bath the motor is humming but no water from jets
you have something lodged in the pump try not to run it until you remove the obstruction or you will damage the pump
Mar 08, 2011 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I need the manual of how to install the bath for the Comet 10 Jet Whirlpool 1500 x 1000 Bath. The Installer is having problem in getting the pump in the right position to work.
i don't have a solution for the manual however, the pump needs to be installed such that the bottom of the suction line going into the pump is 1/2" higher than the bottom of the suction elbow (coming out of the tub) thereby providing the pump with a flooded suction. This will provide the pump enough water to start pumping to the jets.
Feb 10, 2011 | Home
Motor work but jets do not operate
You can hear the pump come on but get no water through the jets?Is the motor running or is it just humming
Feb 10, 2011 | Jacuzzi 9235-959 Nova 6 Whirlpool Bath 6'-...
Lasko pump motor in jetted tub comes on when switch is turned on but doesn't pump any water from jets. Unit has been used very little and is about 8 years old. Is there any such thing as priming these...
you can check to make sure there is water to the front of the pump. What they use on their tubs is called flooded suction pump i.e. there has to be enough water to the front of the pump end to **** it through and push it up and out of the wet end.
fill your tub up and loosen the discharge union on the top of the pump until water starts to come out, quickly tighten the union back down and then see if you can get the pump to start pushing water.
Dec 31, 2010 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Feb 15, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
My whirlpool bath tub has three jets that work & 3 jets that are
The suction IS the water intake. it takes the water from the tub into the pump and the water comes back out through the jets.
Nov 19, 2008 | Home
Home Logo
299 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
