Question about Samsung LTN226W 22 in. HD-Ready LCD Television
Color Blur when i turn on the tv after leaving it idle for about a day it will first turn pink then when i leave it on for a while it turns green but u can see the picture but blurry. the picture looks better when its a cartoon channel. sometimes you can see horizontal lines.ive tried adjusting the colors still nothing.http://merced.craigslist.org/ele/1032350176.html dont know where else to post my pictures
  • 51 Answers
The cord inside that is connecting the power to the screen is loose just either call a repair man or reach inside and plug it in better.
Posted on Feb 13, 2009
Too much red, orange and pink in the picture, little or no green, some blue. No amount of adjusting color, tint or brightness helps it just gets worse. Even turning color off completely leaves it brown and...
mike, mine is doing the same thing - by chance do you use
dish network? I think it's them because both of my t.v.'s are doing the same thing and at the same time...
Sep 05, 2010 | Dynex 20" Digital TV
Projection is messing up. Too much red and blue color.
A CRT projector requires Convergence and Color balance adjustments from time to time. These settings can drift. What you are seeing is a lack of Green color intensity. Do you see some pink in the 'whites'?
The Green CRT surface also burns off faster than the Red and Blue leaving behind the same appearance. As long as your Green CRT is not too burned by gaming or watching Golf and football, a local tv tech will be able to dial it in for you.
Jan 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Unable to get full color, imges often turns pink/orange
Hi!
Go into the menu settings and check whether it has a warmth tint function o, if on then turn it off and adjust the settings accordingly.
If this doesn't work then Maybe a power surge has damaged the box. Try using a different scart/hdmi cable which you know works... it could be a damaged wire.
If not, unplug the box and leave it with nothing connected for 24 hours to get rid of the static and try again. Thanks Rylee
Jan 23, 2009 | Thomson 29DM400 29" TV
TV KOLIN 21"
hello.... do you have any speakers near your television? what color is the circle your talking about? Do the green,pink colors are scattered all over the screen and specially on the corners?
If you have or had speakers near your tv? then do this try to get a magnet.a magnet on a speaker would do.what you have to do is to place the magnet near the screen of the tv approx. above the green,pink color (turn it on first).you will notice the that the color will react with the magnet try to pull it on the side you will notice that the green,pink color is moving on the same direction do it until its gone.NOTE make sure youll not scratch the screen ok.email me what happened. jaredreyesbalderama@yahoo.com GOODLUCK
Jan 21, 2009 | RCA 20F512T 20" TV
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Green Screen
my screen is green.  i can hear audio but no picture.
Jan 17, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
Samsung LTN226W 22 in. HD-Ready LCD Television Logo
215 people viewed this question
Henry  Thomas
Henry Thomas
