Question about Coby TFDVD5000 Portable DVD Player
COBY TFDVD5605 Portable DVD Player repair tips
Hello, I have this DVD player connected directly to 12V car battery,and it works for a while. When i removed the battery and reinserted it again, there was no longer power on it. I also do some repairs being an electronics technician but my problem is that i don't have service manual or schematic diagram to look into in order for me to check the correct voltage output values of the power supply circuit. Would you please help me find one or teache me where and what specific parts that i need to check or replace? Perhaps other Coby DVD player model that has schematic diagram will do because the power supply design might be somewhat similar. Thank you very much for your help. Regards, Joseph
  • 3 Answers
All potable dvd player work on 9V through cig lighter in your car adopters comes in three diffrent sizes.
Posted on Jul 20, 2008
Check the voltage requirements printed on the capacitors in or near the power supply...If they are 16-18 volts, then it probably needs a 12 volt supply.
Posted on May 02, 2012
    Genius:
  • 2,985 Answers
The easy way to discover the operating voltage of as device such as this is to A check the Spec label on the bottom of the machine. Check out the Dry Cell requirements. My guess this is a 6 /9 volt device.
Posted on Aug 01, 2007
SOURCE:
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
Jan 10, 2016 | Coby Televison & Video
The connection with both DC and car charger is intermittent on my coby TF-DVD7051D-P portable DVD player
The power socket on the DVD player has a faulty solder connection. This connector need to be re-soldered to the circuit to fix this problem.
Feb 01, 2013 | Coby TF-DVD7107 Portable DVD Player
My portable coby dvd player wont play with its rechargeable battery after bein charged, the light was blinking and now green but when i take off the adapter and leave the battery it wont turn on?what do i...
Take out the litium battery.Plug in the charger adaptor alone to get power,see if the portable DVD player work.Yes,than the litium battery is dead,not taking in any charges.Tries websites like Partstore.com,Amazon.com,Ebay.com to buy a new exact litium battery or a compatible litium battery.
Oct 18, 2010 | Coby TFDVD5000 Portable DVD Player
I put in a dvd I get sound but no picture.
this is a common problem with portable DVD's. The screen flex is weak, or the screen inverter is bad.
Take the player to a repairer so that the problem can be fixed.
Take care.
Apr 14, 2010 | Coby TF-DVD450 Portable DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
Need new car charger adapter and cords for Coby Twin DVD Players
i need tis car charger adpter and relating cords to my twin coby dvd players replace how to do htis; where to buy im in jacksonville florida .thank you
Jun 25, 2009 | Audiovox PVS72901 Portable DVD Player
My Coby Portable DVD PLAYER
the cover plate broke and will not stay down i need a new one?? I only use this 3 times ocean
May 20, 2008 | Coby TF-DVD7006
Dratted Coby TF-DVD7100 Portable DVD player not working!
Its defective. Coby doesn't repair the units. The lense is off balance which is causing the laser to not read the dvd/cd.
Apr 17, 2008 | Coby TF-DVD7100 Portable DVD Player
Coby TFDVD5000 Portable DVD Player Logo
839 people viewed this question
Top Coby Televison & Video Experts
Ekse
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
