Dell Dimension 3100 PC Desktop
Problem for Dell Dimension 3100 PC Desktop
Find what driver I need or a solution to the problem
By albertrn2000 on Feb 12, 2009
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
This is the device Windigo Virtual Audio Device (WDM).
Hope you can help.
Comments:
Feb 12, 2009
- One I have added it is some thing to do with LOGITECH
Feb 12, 2009
- My dell has nothing to do with it LOGITECH.
Feb 13, 2009
- Yes I have Mcaffy Anti virus.Will try your solution to see if it works do you no which driver I should download?
Thank you..Chris
Feb 14, 2009
- Windows Media Center 2005
Feb 19, 2009
- My computor has Windows XP MEDIA CENTRE VERSION 2002
Clarification Request
Posted by bruxy on Feb 13, 2009
albertrn...
your logitech driver is probably for mouse & keyboard or webcam... you need to download the drivers for the WDM card that the experts here are posting links to... and then you need to install them.
the drivers from your original installation have somehow been corrupted... maybe you had to re-boot by button or the computer rebooted on its own and the file got messed up.
if you go to your start menu and click 'Run' and type in: chkdsk.exe that might help, and may solve other problems in your computer, but you still may have to reinstall the drivers for your sound card.
also, if you type chkdsk.exe /f you will be told you can't do this now and if you want to you can run a disk scan when you reboot... type Y for yes and then Exit to leave the window. when you reboot the computer the scandisk will run (it's a blue screen) and correct any problems it can't fix when you're already in windows.
a quick question... do you have an up-to-date anti-virus installed?
bru*
Posted by ChrisN315 on Feb 12, 2009
Is this a sound card that came in the PC or is it one you've added?
Posted by bruxy on Feb 12, 2009
Hello albertrn...
you probably need ot re-install the device drivers. do you have the disk with the drivers and/or software for your soundcard?
also, what operating system are you running?
bru*
Solution #1
posted on Feb 13, 2009
Somewhat Helpful)
bruxy
Rank: Guru  Computers & Networking  Expert
Rating: 87%, 42 votes
hi albertn aka chris :)
there are some links to the downloads in the other solutions posted, this is the starting page for them...
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
you will get a popup window, put your service tag number in there and follow the directions from there... i think dell will tell you which driver you need if you put in that service tag information, and then specify that you need the drivers for WDM.
once you download them you just have to run the program to install the new driver... if it asks you if you want to overwrite any files, say yes... if after doing this you are still getting this error, you can try uninstalling the drivers and then reinstalling with your new download to be sure all the associated files are the new ones.
please read the solutions above this one as well... they do point you in the right direction!
oh, and let me know if you don't have the service tag number... you should though, it's kinda important...
bru*
Comments:
Feb 13, 2009
- ps... let me know if there's something you don't understand...
you should try to scan your hard drives with your antivirus... if all is clean, try the scan disc (chkdsk.exe that i explained earlier) and then install the drivers if things are still not working properly.
also you might want to try turning off your antivirus when you install the drivers... sometimes that can be a problem... just remember to turn it on afterwards... only do this if you have already scanned and your computer is clean.
Was this helpful?
Yes
No
Solution #2
posted on Feb 12, 2009
Somewhat Helpful)
womonsoft7
Rank: Guru
Rating: 86%, 70 votes
In the Properties section for the WDM, uninstall the device driver. Restart your computer and let it scan for hardware changes, and let it search for the necessary drivers online and follow the prompts to install the driver(s) that your computer finds.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
ashish13
Rank: Guru
Rating: 85%, 80 votes
The problem is cause by a faulty driver for your optical drive. You need to download n install the latest drivers for the device. You can download the driver from here :
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_P4_3100&os=WW1&osl=en&catid=&impid=
Select the driver according to your device by first checking in the device manager {Right click on My Computer... go to propertied n then click the hardware tab}
Was this helpful?
Yes
No
Solution #4
Somewhat Helpful)
Smithbrother
Rank: Wiz  Dell Computers & Networking  Expert
Rating: 82%, 1412 votes
Here is the link to the driver download site for you model Dell. Their seems to be two audio device downloads. cLikely one the driver and the other the device itself (software).
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_3100&os=WW1&osl=en&catid=&impid=
Was this helpful?
Yes
No
Solution #5
Somewhat Helpful)
dgbrimm
Rank: Master
Rating: 78%, 9 votes
You can also get the driver by using the Service Tag located on the PC tower by going to http://support.dell.com
There you can enter the service tag, select the Operating System, and then choose the correct audio driver for your computer. This should resolve the issue.
Was this helpful?
Yes
No
Solution #6
posted on Feb 18, 2009
Not Rated)
blueextc3221
Rating: 90%, 1559 votes
A dell Dimension 3100 (your selected item) was shipped with Windows XP or Vista originally. NOT Media Center 2005.
Is the model of your PC listed properly??
Your device will not be recognized by the PC without the correct Device Driver installed, and If we do not know the proper information... NOBODY can give you the correct answer!!
Thanks for using FixYa - a FixYa rating is appreciated!!
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 3100 PC Desktop
Questions and Unsolved Problems for Dell Dimension 3100 PC Desktop
Do you recommend Dell Dimension 3100 PC Desktop?
Answer
Answer
How can I print off one frame in a video file?
Answer
how to get dell desktop de051 lan drivers
Answer
my computer can't seem to detect my speaker. they are connected to the correct port but i still have... (More)
Answer
Have been trying to install Draw Plus X3. Talked to Alex at length; still no results. I think I got... (More)
Answer
intermittent startup problem. power light goes from blue to orange to out. it worked fine at BestBuy... (More)
Describe your PC Desktops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
in , OH
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
