Home | Dell | Dimension 4600 PC Desktop | Windows cannot load the...
Dell Dimension 4600 PC Desktop
Problem for Dell Dimension 4600 PC Desktop
Windows cannot load the device driver for this hardware.
By albertrn2000 on Feb 12, 2009
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
This is the device Windigo Virtual Audio Device (WDM).
Hope you can help.
Comments:
Feb 12, 2009
- Thanks but I think the problem is with a Logitech product and not Dell,when you go to hardware in systems there is a yelow dot with this ! in the middle and when you go to properties it says it is not function prop and the error code 39
Solution #1
posted on Jun 27, 2009
Not Rated)
dilipbagdi
Rank: Guru  Dell Expert
Rating: 88%, 1363 votes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Was this helpful?
Yes
No
Solution #2
posted on Feb 12, 2009
Not Rated)
dgbrimm
Rank: Master
Rating: 79%, 8 votes
have you tried going to support.dell.com and downloading the driver again?? There may be a new driver or at least it could replace the driver that may have become corrupt. You can search their drivers by the service tag that is on your PC tower and it should allow you to select the correct operating system and then choose the correct sound driver. Hope this helps... If not please provide more info
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 4600 PC Desktop
Questions and Unsolved Problems for Dell Dimension 4600 PC Desktop
Do you recommend Dell Dimension 4600 PC Desktop?
Answer
Answer
How do I connect hP e9240 to direct tv to use my multimedia software
Answer
Require Packard Bell Easynote R1938 disassembly instructions
Answer
How do I get my Namco all-stars pac-man game to use a gamepad instead of the key board? I can't get... (More)
Answer
Hi. I'm using a Asus M2N-E motherboard and when I do a CMOS HDD's start to spin Fan of VGA Processor... (More)
Answer
GA-8TRC410MNF-RH Hello, I have given this motherboard and I know the position of the panel... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 4600 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
