Question about Sony KP-51HW40 51" Rear Projection Television
5 flashing light code,unplug CR board,now 8 flashing light code
Sony KP-51hw40 - Has 5 flashing light code and tv shuts down after blue and green tubes light up and red doesn't. Was told by Ladywinn to unplug red tube CRT board and see if the tv stays on. I hope that is the CR board at the bottom of the yoke and V-board assembly. I unplugged the CR board ,the tv shuts off and get 8 flashing light code now,which is audio I think.
    Novelist:
  • 184 Answers
If you put the "CR" board back on, the error code will once again be 5 blinks. Your problem is likely the TV's IK blanking circuit. The Kine driver ICs on the CRT sockets boards CR, CB, and CG need replacement along with a few components in the 200 volt supply to the circuit.
Posted on Feb 13, 2009
Blinking green power light on WD65737 for a minute or so then shut down, Will also go to welcome screen and then shut down
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jan 13, 2017 | Mitsubishi WD65737 65 inch DLP 1080p HDTV
Sony projection tv...Screen blinks on and off to black several times a minute...audio and everything else is fine
It sounds like either the inverter board or lamp are the problem. I would sway more towards the inverter as when the lamps die they normally do it properly.
Jan 13, 2017 | Sony Televison & Video
I have a Sony kds-60A2020 with no sound or picture two green and 7 red errors code
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 12, 2017 | Sony Televison & Video
MY dstv DSDD 1132 decoder is flashing red and green lights but yellow light is steady. tv is black and remote not responding
Jan 12, 2017 | Televison & Video
I have a 60 inch sony tv that have a red flashing on the lower left side,no picture when I turn it on and there is ringing sound.
Jan 09, 2017 | Sony Televison & Video
I have a Sony LCD Digital Color TV Model KDL-40S5100
try this --as you are wasting time and will eventually waste money---take it to a repair shop for a proper diagnosis and quote
Jan 08, 2017 | Sony Bravia KDL-40S51009 40 in. TV
The color on my TV is all pink. I have tried a hard reset but it didn't help.
Your TV has lost a GREEN color from a basic color palette (Red-Green-Blue). It is often caused by:
- damaged LCD cable (which connects the display with a signal board inside the TV),
- damaged video signal cable (ex. SCART, HDMI, VGA),
- damaged video processor (on the signal board).
I can't give you a more accurate answer, because I don't know what is your TV mark and model and, in what situations you have the problem.
Jan 19, 2015 | Televison & Video
Sony bravia shuts off
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 30, 2014 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
Sony KP-51HW40 51" Rear Projection Television Logo
238 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
