I have a dell laptop on start up it goes to a blue screen and says unmountable_boot_volume
  • dalecawley Feb 12, 2009
    it wont go into safe mode
    Problem Solver:
  • 7 Answers
Well, the good news is that your system is still detecting your hard drive. The bad news is that your Windows installation is corrupted somehow.
If you're using System Restore, you could try booting in Safe Mode by hitting F8 a few times while the computer is starting (after the BIOS screen, where it mentions RAM information, but before the Windows logo comes on). If you get a menu, choose Safe Mode, then use System Restore to go to an earlier restore point.
It isn't always, but it's usually an indication of a failing hard drive. If you have important information on that drive that you haven't backed up (tsk, tsk), you should really do that, in case it's about to crash completely. You didn't specify the model of the laptop, so it might be a SATA drive, but it's probably an old, IDE one, in which case you'd need a 2.5 - 3.5" converter, and you'd need to set that up in a functional PC as a slave drive. Otherwise, pay someone else to do it for you (are you in the Chicago area? If not, are you someplace warm and willing to pay for travel? Please?).
Then, try repairing Windows. Boot from a Windows CD, the select the installation and press R for Repair.
Posted on Feb 12, 2009
  • 258 Answers
Try tappng the F8 key during start up and select safe mode
Logon and click on the right hand answer to go into system restore
Restore my computer to an earlier time
Select a bold date from the calender on the left, choose a date before the error occurred
Next select a system checkpoint or other point for that date from the right hand side
Click next
next
good luck HPC
  • Peter Conway Feb 13, 2009
    If the Repair doesn't work, backup all your files and make sure you have all your software on disks, then, depending on it's age with Dell PC's it may have a recovery partition.
    try this : During the computer startup press and hold the CTRL + F11 keys
    Follow the instructions for Restore to Factory Settings
I have a blue screen that says "UNMOUNTABLE BOOT VOLUME" And system will not boot up any further?
This means that the hard disk drive has a problem. It could be an electronics failure or it could be a driver problem. Try to start the computer in SAFE mode by pressing the F8 at bootup. This will verify the hardware.
Jul 14, 2014 | Dell Inspiron B130 Notebook
Unmountable boot volume
Please boot from bootable disc and repair the OS.
Mar 19, 2012 | Dell Computers & Internet
How to remove the unmountable boot volume 1525 dell inspirion be cuz i have the blue screen, try go to the safe mode but freeze after it shows all the hard drive data its a stand still
if you can boot normally i suggest going to filehippo.com or cnet and download a free disk partioner and it will remove the boot volume for you. under run, msconfig, there is a boot option select the boot mount you want that may fix it let me know
Mar 15, 2011 | Dell Inspiron 1525 Notebook
My dell computer when i start it up goes to a blue screen it says windows did not start propperly then it takes me to a blue screen and says unmountable boot volume
You need to repair the Master Boot Record. This is a fairly complicated procedure so if you are not confident in your computer skills, this issue is worth hiring a professional to handle.
What you will need is a bootable CD, such as a PE application, which you can use as a platform to run checkdisk.
Boot from this CD and then un-mount your internal hard drive. Run CheckDisk (chkdsk command on cmd) with both of the parameters /f and /r
This should go through your hard drive and repair your MBR.
Reboot your computer and you should be good to go.
If this does not work, run a repair-reinstall. This reinstalls all system files including your MBR and bootable files on the X drive.
Good luck, please rate my solution!
Jul 08, 2010 | Dell Inspiron 1501 Notebook
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
I have a code 7
If this issue can be fixed, a good start is going to be..
Boot from your windows installation cd, then access the recovery console.
At the command prompt your going to need to run chkdsk /r
here is a link to microsoft that goes into greater detail on this issue.
http://support.microsoft.com/kb/555302
Apr 22, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
UNMOUNTABLE DISK VOLUME Message on ACER Aspire One.
Unmountable boot volume is most likely an indication of a failing hard drive. Boot to your Windows CD and run CHKDSK /R and see if issue resolves. If it doesn't then you are probably replacing the hard drive.
Sep 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
Blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Jan 18, 2009 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
63 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
