Question about Sharp AL-1551CS Copier
Error code L1
When I turn my Sharp copier AL 1551CS on it sounds like it is warming up and I hear a click and error code L1 comes onI have the same problem
    Sergeant:
  • 219 Answers
The L1 error code means that, "The Main PWB sensed that the Exposure Lamp Carriage did not leave the home position after power up or after the Start button was pressed."
Apparently something is wrong with the scanner portion of your copier. Have you checked to see if the glass is bulging towards the lamp carriage which might prevent it from moving?
Posted on Feb 12, 2009
    Genius:
  • 1,269 Answers
Make sure the lock lever is unlocked, unplug the power cable for few minutes as well.
2 Suggested Answers
claudiomn
  • 10 Answers
SOURCE: error code L1
Next exit paper have a key block scanner. Put knob in key out  for work well. Power off and power on. Good luck.
Posted on Jan 17, 2009
Why is my Sharp AL-1551CS displaying error h4?
replace the fuser, do not continue to reset or the machine can catch on fire try this site a fuser unit as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 13, 2015 | Sharp AL-1551CS Printer
My sharp AL 1551 CS is getting a L1 error code before that it was getting a E7 code. The scanner will light up and shut right back down, then it shuts itself down again.
I have a tip posted here on Fixya that will help you diagnose and repair an L1 failure code on the Sharp AL series copier.
Here is the link:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
If this works for you then please return here and give me positive feedback.
Thanks for using Fixya today.
Jul 13, 2010 | Sharp AL-1551CS Copier
I have a Sharp AL-1551CS that when turned on shows an error message and will not work. The error code referenced in the maunual says to remove the shipping screw. I have had this unit several years. what...
instead of a screw, some models have a dial to lock the scanner for moving machine. look above where the paper exits machine twords the left side under the scanner assembly for a dial switch and turn it.
Nov 11, 2009 | Sharp AL-1551CS Copier
Err0r l1 00
If you hear any cracking sound if you are not please clean all surface scanner area.Clean scanner sensor
unlock position .
Oct 07, 2009 | Sharp AL-1655CS Laser Printer
My al-1551cs sharp printer displays L1 and nothing works
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Jun 09, 2009 | Sharp AL-1551CS Printer
Copier mod AL-1551CS gets a E7 error code and lock up. Whats up?
The E7 code is related to the laser and or the distinction between black and white being read/interpreted by the system. There should be a sub code which will point more directly to the problem. The laser could be bad or the glass and mirrors need cleaning. Remove the glass (with the copier unplugged) and clean including the white strip underneath, clean mirrors too.
Mar 20, 2009 | Sharp AL-1551CS Copier
Error code L1
Jan 17, 2009 | Sharp AL-1551CS Copier
H 4 error
If the Reset does not work, then you have a fuser error and your machine will need service.
H4 is a fuser heating error code.
Meaning the machine is not warming up because of a bad lamp, thermal fuse, thermostat, and or thermister.
Hope this helps.
Good luck.
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
Al-1551cs / L!
Sharp Error Codes
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Sharp UX-170 maintenance mode: Turn power on, set the line selector at "T" (tone), turn the program switch ON, then press 9 * 8 # 7. Select the next entry from this list: 01 all black copy, 02 ROM/RAM check, 03 auto feeder mode, 04 aging mode, 05 panel check mode, 06 G3 transmission, 07 check pattern, 08 product check (includes diags, 06, 03, 09), 09 signal send mode, 10 memory clear, 11 led array on mode (lamp), 12 product program sw mode, 13 telephone number list printing mode, * soft switch mode, # transmission level. This same procedure works on similar, older models that do not have an LCD display.
Sharp UX-2100 often has power supply problems which cause the unit to lock up.
UX-3200/FO-3250: FO32TD toner/developer costs less than UX30TD and will work in the UX model if 2 fins are broken off so that the unit can be installed in the UX model. Similar duplicity exists with many Sharp laser supplies.
Sharp FO-4800: fuzzy print often results from a bad Motor PWB (polygon mirror) #RMOTN0020GCZZ located in the optical unit.
Nov 06, 2007 | Sharp AL-1551CS Printer
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
