Question about RCA R52WH76 Television
Convergence problem I was given a rca model (R56wh78) chasis # ITC222A. I have read many of the posts, and I have the approximate 300 volts dc to the convergence board, # nna600110b, I cant find any open diodes on this board, but from the looks of things this can be the only cause, question, I don't want to pull the fuse by the flyback, If I have pwr. to the board I would assume the fuse to be ok, so can the board go bad without blowing the fuse, and should I just replace the board or do you think there will be multiple problems after I invest the money for the board, the convergence mode from setup is not showing, and convergence is bad, hope I have given you enough info, thank you
    Novelist:
  • 184 Answers
Yes, the convergence circuit can fail without blowing any fuses. These Tvs are tough to repair because the convergence output devices are transistors and there will be other small components damaged as well. Get an estimate from a reputable service center before going any further.
michtech
Posted on Feb 14, 2009
The picture on my RCA R56WH78 is blurried
thats the ITC222A chassis which is famous for deflection board issues which cause misaligned colors. You can get free assistance to figure it out by responding to this same post and leeting me know if you still have the auto convergence option still listed under the setup menu or has it disappeared from the setup menu options.
Mar 18, 2013 | Televison & Video
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
WHY DOES'NT MY RCA MENU HAVE CONVERGENCE PROGRAM R56WH78 TURNED IT OFF FOR 10 HOURS TO REBOOT STILL NOT THERE
Blowed fuse on the deflection board FL231.06 amps it will be located on the right hand side of the FBT flyback Transfomer
there will be 3 of them in a roll small brown or gray rectangler looking caps but they are fuses it will be the one in the middle
Partstore.com has them. Deflection board is locted on left hand side of bottom chassis.
Jun 05, 2010 | RCA D52W23 52" HDTV CRT TV
3 color curved band lines on my RCA tv.
Ur convergence is dead.U must know how to do soldering to fix this problems?Must replaced 2 STK convergence ICS,and some or all it resistors too.Tries websites Tv repair World.com,Tvrepairkits.com to do the reapair it ur self.The shop will cost U $300 for parts and labors.
Mar 20, 2010 | RCA R61WH76 61" HDTV
I have 3d on my 52 inch rca and go to set up convergence isnt there now.is this something i can fix?
Yes its a easy an inexspensive repair. www.tvrepairworld.com has the ITC222 and ITC222A convergence option missing repair kit. The kit contains the parts and CD with instructions.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca r52wh74yx51 chasis itc222a convergence
These sets do not have convergence ICs it has convergence board most common problem with them is if you go to menu then setup and do not see convergence on menu then you have a open fuse FL231 they are located on right side of FBT flyback transfomer thier is 3 in a roll small brown rectrangler looking caps but are FUSEs it will be the one in the middle.
Aug 14, 2009 | RCA Televison & Video
Convergence problems with rca r56wh78 how can i fix it?
go to the following link and leave them a email with your model and symptoms and they will assist you with the proper component that will need to be replaced to correct the issue and they help with free instructions when you order the components.
http://servicemanuals.vstore.ca/
Apr 25, 2009 | RCA P52926 52" Rear Projection Television
RCA HD52W59 Distorted colors and bowed pic.
in customer menu under setup do you have the convergence option. If you do not it probally be that fuse. this fuse is located on the main defection to the right of what know as flyback.. which is a large black component with two large red wires coming from it.
Nov 07, 2008 | RCA HD52W59 HDTV Projection Television
Convergence on a r56wh78 rca projection tv
I located the problem with this set and wanted to pass it on to help anyone with this problem. the chassis # is ITC222A and the problem turned out to be a fuse on the High voltage board. There are 3 fuses that sit next to the flyback transformer and the middle fuse (400 ma 125v) was blown.
Mar 21, 2008 | Televison & Video
RCA R52WH76 Television Logo
334 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
