Question about GE GSS22JF Side by Side Refrigerator
GE fridge GSS22UFPA side by side freezing food
My approx. 5 year old side by side refridgerator has started freezing food, mostly towards the bottom of the fridge. It started in the produce drawer and mostly effects produce, but yesterday it froze my carrots on the middle shelf. Liquids are not freezing on the top shelf yet.
  • midoriiBlue Apr 01, 2009
    Different model, but same problem. Mostly freezes at the top, but certain items freeze no matter where I place them. It had been freezing on and off in cycles for about 6 months and I finally had a new company come out and look at it. So far I have had the cold control and thermostat near the damper replaced. The mother board, heater, and thermostat for the freezer side were replaced about 6 months ago when the fridge side wasn't working (the freezing problem started right after that). Since it has been worked on again the temperature fluctuates between 0 - 18 degrees F on the top shelf. Not sure what to do next
fridgetech
  • 473 Answers
SOURCE: Amana ABB1927DE lower drawers freeze and lock potential
Cold air settles to the bottom of the fridge. Things that can freeze easy may if the door is closed for long periods of time. This is a normal condition for any refrigerator. Look to see if there is a vent that goes to that drawer and close it all the way. That may make a difference.
Posted on Oct 07, 2007
Sea Breeze
  • 4655 Answers
SOURCE: Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Posted on Oct 27, 2007
  • 833 Answers
SOURCE: Refridgerator freezing food
dm, I'm not sure if the thermostat is mechanical or electronic. Assuming mechanical...and I do...turn it to the lowest number...does it turn off? If this works properly, the problem is likely not the control. Does the compressor turn off at any time? If not after an hour or so of operation, the stat could be defective. That's my first guess. Oh, have you made sure that you don't have the ducts in the freezer blocked? The would deflect too much cold air to the fridge section.
Next, defrost the unit and clean the condenser coils. This will help the unit work properly. Then, wait awhile with the unit off. Meanwhile, access the compressor in the rear of the unit. Find the largest pipe coming out of the compressor. Turn the unit on. The largest pipe should frost and then, in about 5 minutes or so...either cause condensation or dry out. If neither happens and the line is either not COLD to the touch or frosty, you're low on gas. If the unit is less than 5 years old, you may get warranty coverage on the sealed unit from the mfgr. Believe it or not, too little gas will cause freezing in some cases!
Posted on Nov 28, 2007
peyton32034
  • 410 Answers
SOURCE: Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Posted on Dec 16, 2007
  • 37 Answers
SOURCE: SIDE BY SIDE Frig & freezer
hurlsdad.
Sounds like a noisy evaporator fan. Take the shelves out ot the freezer then take the panels on the back wall of the freezer off. The fan will be there. Then you will know for sure thats the source of the noise. When it is time to replace it...easy fix. (few screws) Here is an excellent source for the part..www.repairclinic.com. My favorite place for appliance parts.
hope this is helpful,
handiman518
Posted on Jan 16, 2008
Our 3 year old GE refridgerator door seems to slam shut. could you give me some ideas for me to check and our refridgerator seems to be freezing the food. It freezes the milk on top shelf and freezes our...
make sure the fridge feet are even at the front it would seem the feet are too high and the fridge is on a backward lean allowing gravity to slam the door as there a re no springs in the door it can only be this
merry christmas
Dec 21, 2010 | Refrigerators
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Jan 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Nov 28, 2007 | Kenmore 53212 / 53214 / 53219 Side by Side...
GE GSS22JF Side by Side Refrigerator Logo
202 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
