Question about Fujitsu Siemens Computers & Internet
Amilo Pro V2030 - Wont Boot
I have an amilo pro. When I turn it on the only light that comes on is the hard drive light and it wont start up. No picture on screen. The fan is running but not doing anthing else was working about a month ago havent used it for a while. Can anyone help?
  • t_kudmany Feb 13, 2009
    I have tried the external monitor and nothing tried pressing FN and F3 but no pic. The hardrive makes no noise and just seems to sit the. Even if I leave it for a while and try to engage some light i.e by pressing FN and num lock, no lights, nothing.
  • Fujitsu Siemens Master
  • 4,806 Answers
HI there
Have a look very close at the monitor for a very faint ghost image, if you see one then the inverter or inverter coil has gone.
Another way is to plug an external monitor to the laptop to rule out other problems.
Post back if you need to.
Good luck and thanks for using Fixya!!!
Posted on Feb 12, 2009
  • Lee Hodgson
    Lee Hodgson Feb 13, 2009
    Hi there
    You seem to know what you are doing with the keyboard switch screen.
    Take the system memory out and clean the contacts and the slots with a clean, dry soft paintbrush, if there are more than one memory modules, put them back 1 at a time powering up the laptop between.
    Post back please
    Good luck
    President:
  • 778 Answers
Try connecting it to an external monitor as the display may have gone out on you.
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
The display on my Amilo Pro V2030 is black after it fell on the floor. Does this necessarily mean that the display is dead and needs to be replaced or external monitor used? Could the problem be fixed in...
May be a loose connection, at best, at worst, HDD damaged, etc., etc., etc.. Does it boot? Fan spins? LED's Blink? Sound? Anything? If you connect a External Monitor does it work? There are cable at the bottom and rear of the monitor that can come loose.
May 04, 2013 | Fujitsu Siemens Amilo Pro V2030 Laptop...
Amilo pro v2030 laptop
oh boy,, !!! ur screen is damaged and better replace it !! no choice left !!! Hard luck ...
May 04, 2013 | Computers & Internet
Fujitsu Siemens AMILO Pro V2030 Not Boot, power button doesnt do anything. Only charging light is on when plugged to power. What should be done?
You have a problem on the motherboard.The power regulator circuitry in laptops is on the motherboard. You'll need to take it to a repair shop.
Apr 04, 2011 | Fujitsu Siemens AMILO Pro V2010 Notebook
My fujitsu seimens amilo pro 3515 wont boot. I turn it on and can hear it start to do something but then nothing on screen, only the sound of the fan running. Any idea what I can do?
check if battery is good or the adapter but if you sure the fan is rotating then problem maybe on hard drive or memory if you can do it, try to re-install it memory and hard drive and clean the memory or sata, ide slot. or check the operating system maybe it crash or file corrupt.
Feb 12, 2011 | Fujitsu Siemens Amilo Pro V3515 Laptop...
Sos
Here is the
LINK
to the download page for the audio drivers, on Fujitsu's site... specifically for the Amilo Pro V2030.
I hope that helps.
Jan 21, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujits amilo pro v2030 will not boot up
Are you getting the BIOS info on the screen?
If you can access the BIOS check all the setting.
Hard Drive installed, Boot Sequence and so-on.
If you get NOTHING on the screen but can hear it "running", try plugging in a Monitor, you may have to find the monitor key, usually = hold "Fn" + Press "F5" to switch screen to monitor to both.
Oct 08, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
No vga driver for amilo pro v2030
You can find the driver link here. Amilo Pro v2030 VGA Driver scroll down and you will find the link "VIA/S3G UniChrome Pro IGP". you must register first to download the driver. Just use free Membership in signing in and just skip or select no thanks in other membership offer..
Hope I Can Help
CLCTECH
Apr 28, 2009 | Computers & Internet
Win xp sp 2 and fujitsu siemens amilo pro v2030
here is the link for driver download it otherwise i will try another driver if it doesnt work with SP2 ok
http://webdownload.fujitsu-siemens.com/download/FileDownload/fileDownload.aspx?SoftwareGUID=F8D86EE3-5A24-4F8B-9FBC-3BA22CD6B7F2&FileFolder=Downloadfiles&FileTypeExtension=ZIP&FileNameClient=FSC_GemtekWMIB160GW_3100641_1003614.ZIP&FileSize=29309648&From=VXZ0Z2NvSGtuZ1ZxRHRxeXVndCAo
pls consider rating me FIXYA if i helped u
Mar 31, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Amilo Pro V2055 Wont start up
Try reseating the memory and the hard drive if you can remove it easy enough, if this doesn't work you may need to take it to your local computer repair shop.
Good Luck.
Feb 18, 2009 | Fujitsu AMILO PC Laptops
Computers & Internet Logo
698 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
