Question about Kenmore Oasis HE 27082 Top Load Washer
Cycle Signal Volume beeps from loud to soft
The Cycle Signal Volume lights and beeps from loud to soft over and over. Can not stop it from beeping continually during the wash.
  • 1 more comment
  • Sandy Knecht Feb 13, 2009
    jsrock516,
    Thank you very much, my model number is 110.27087603.
    sandy
  • Toto21 Feb 15, 2009
    This is so annoying!  We just bought this washer last Spring.  I can't do one load without having to keep running back and forth to the washer to get it to go again.  I usually move the clothes around a bit with my hands.  Then it works for another 10 minutes! Aaaagh!!!
    With every load I have to run to the washer and move around the clothes in the washer.  Then after about 10 minutes it beeps again!
  • 5,911 Answers
This is a common and very well known problem with the Oasis. You will need to replace the operator interface board inside the control panel to resolve this issue. The board is located directly behind the control knob. If you post back with your model number, I can research a part number for you, give you info on where you can order a replacement, and give you guidance on how to replace the board yourself.
Posted on Feb 12, 2009
  • Jeff Rockwell
    Jeff Rockwell Feb 13, 2009
    Thanks for the reply. You can order the part on line at searspartsdirect.com. Just type in oyur model number and look for item 7 under the "Control Panel Parts" heading. The part number is 8564392. Appliancepartspros.com carries this same part for only $124, but I could not find your model number on their website. So...do a search by part number (using the part number provided) and you will find what you need for a little less. The reason I still reference the first website is because the drawings may come in handy to you.
    To replace the user interface board, follow these steps:
    1. Unplug the washer.
    2. Locate and remove the retaining screws in the back of the control panel. With the screws removed, the control panel will lift from the back first, then off. NOTE: Be careful when lifting the panel, there is a small interface cable plugged into the control board.
    3. Remove the interface connector and pull the control knob off.
    4. Lay entire panel face down on a soft surface (such as some folded towels).
    5. Remove the user interface cover (this is item 10 if you use the drawings in the Sears website).
    6. With the cover removed, take a small flat blade screwdriver and pry back the tabs that hold the board in place. There will be several around the entire perimeter.
    7. Once the old board is removed, carefully insert the new control board making sure you don't put it in upside down. Mark the location of the interface connector plug as a reference. NOTE: Do not handle the surface area of the board with your hands. This can cause damage to small components of the board and render it unusable. Hold the board by the edges.
    8. Reinsert the interface cover and flip the control panel over to its upright position.
    9. Reinstall the control knob and make sure you plug the interface connector back in.
    10. Reinstall control panel by inserting the front edge of the panel into the grooves on the washer top casing and lower it back. Tighten all mounting screws.
    This is a pretty simple repair job. The hardest part you may encounter is removing the old board. The small tabs can be difficult to bend sometimes. Also, use care not to apply too much pressure on the new board when you install it. They can be difficult to snap back into place at times. Just take your time.
    If you have questions along the way, please let me know. I hope this corrects your problem.
    PS You may also try unplugging the washer and removing the control panel and try cleaning the interface connector to see if this helps BEFORE you order parts. Sometimes it does.
Want to stop buschh dishwasher shx43p15uc from beeping at end of cycle
To turn off the cycle completion signal on a Bosch dishwasher, please do the following:
1. Press and hold the right "CANCEL/DRAIN" button then press and hold the "ON/OFF" button
2. When the light above the "CANCEL/DRAIN" button illuminates and the beeping starts, release both buttons
3. Press the right "CANCEL/DRAIN" button repeatedly until the tone is at the desired volume, i.e. silent
4. Press the "ON/OFF" button again to confirm/set the desired volume.
Happy Holidays!
BElectric
Dec 24, 2010 | Dishwashers
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
It won't stop beeping all the time. We have tried everything. It beeps 3 times, all the buttons light up and it makes me crazy!! I want it to beep when the load is done - that's it.
When the Cycle Signal Control is ON (turn off) a signal will sound at the end of each cycle and
during the Press Saver setting (some models). The volume is adjustable on some
models.
Jul 18, 2009 | Frigidaire FEQ1442ES Electric Dryer
How do I turn off the beepers on my Bosch washer
To turn the beep off (or volume down) on the Exxcel 7 (BOSCH WAE24468GB you do the following:
1. Turn setting dial to off. 2. Turn dial one step clockwise (wait for panel to light) 3. Keep finger on 'RPM' button and turn dial another step clockwise and release finger. 4. The default setting of '2' should appear on the display, this represents the Button Signal Volume 5. Pressing 'Ready in' button cycles through the volume settings from 0 (off) to 4 (very loud!). 6. Turn dial another step clockwise to set the 'Information Signal Volume', which is also set to '2' by default. This is the one that annoys everyone at the end of the cycle!
All the manuals are on the Bosch website, if you know the model code.
Mar 07, 2009 | Bosch Washing Machines
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Loud/Soft signal
all i can figure is it is a strange method by kenmore to alert the user to throw in an antistatic cloth that gives softer clothes (clothes softener sheets)
May 25, 2007 | Kenmore 67052 Dryer
Kenmore Oasis HE 27082 Top Load Washer Logo
236 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
