Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet Gray ceramic seal broke.
On the Drum of my washing machine ( model GHW9100LW1 whirlpool duet front loder) there is this gray ceramic hard clay ring. It broke. Where do I get the parts to fix it? How do I get step by step instructions on how to fix it? Any help would be nice.
  • 5,911 Answers
If you are talking about the counterweights, they can be ordered on line at Just type in your model number and look under the "Tub and Basket Parts" heading for items 9 and 15. Now depending on which counterweight broke (they are located on the back and front of the tub), the procedures to replace differ slightly. Can you place post back and let me know if it is the front or the back counterweight that is broken? If I am incorrect about the part you are describing, please elaborate a bit more and let me know which part it is.
Posted on Feb 12, 2009
Drum won turn
Wow, check around the bellows, gray rubber seal in front between the stainless basket, remove any item. Didn't find anything now unplug unit remove top and lower machine covers. Run the flashlight along the outer tub while looking inside the stainless basket, locate any items that may jam rotation of the inner basket and remove.
Oct 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer clunks when spinning & the plactic sheild between stainless steel tub & gray rubber seal is chewed. Any solutions to the problem would be greatly appeciated. This is a Whirlpool Duet model...
Hello, Thank You for using FixYa. I will be helping you today.Remove the back panel the center nut on the pulley may be loose and most of the time the pulley needs to be replaced when this happens. If you remove the nut you can see the pulley should be tight around the shaft its in no play or movement. If its ok tighten the nut and you should be good. If its not loose you would have to replace the front and rear outer tubs and spin basket which is well over $500.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Washing Machines
How to change Whirlpool Duet front-load washer (model: GHW9100LW1) rubber seal (the bit gray rubber ring that's between the front door and the drum)?
If you are referring to the door bellow, the following link explains step-by-step how to replace one:
If you haven't purchased a replacement yet, you can find one at any of the following web sites:
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Aug 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9100LW1 the machine is leaking and not draining property what do i need and where can i find these parts
depending where the leak is,in the rear it could be the wash tub seal in which you need new seals and while its out replace the bearings,if its in the front,then either your door boot seal is torn or the drain "weep" hole is plugged by soap scum and mildew
Mar 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
One of the gray bars inside broke? Where can I order one?
You can go to for most all parts. Thats where I get mine... Or you can get the factory parts at whirlpool I use them too.
Aug 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud grinding noise only during the spin cycle.
Try looking at the solution for loud noise during spin with gray water in drain. This also sounds like the bearings on the shaft supporting the stainless steel drum, in the aft half of the outer drum.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet: gray plastic agitator poece inside drum broke off
here's the part number for the replacement 8182233, thinking it may come as a 3 pack , if they're not broken no need to replace. but the new one will simply slide in and with a click forward lock into place. they also come shipped with a screw to secure. in order to install screw you'll need to remove the top of the washer(3 screws across the back of the top assy and slides back and off. then you'll see the top of the tub area, a small black hose will run from the white box to the left to directly top of the tub assy. remove ethe hose from the tub and spin the inner drum to the correct position, they screw hole will line up through the opening, re-secure the hose to the tub and your in!
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet
firstly you will need to unplug the machine, then remove the lid, open the door and remove the metal retaining band from around the lip of the door seal (may need a small flat screwdriver to lift it up).
once the retainer is off the door seal should pull away from the front lip, this can then be folded inside the machine and out of the way for the next bit.
next you will need to locate the doorseal retainer on the inside of the machine may need a 7mm socket and small ratchet or a small philips screwdriver for this one, this one only needs to be loosened enough so that the doorseal will pull away from the drum.
refitting is pretty much the reverse of removal.
you MUST make sure the seal is on the drum lip corrrectly before refitting the retaining band or it will leak.
you MUST also make sure the drain holes are lined up with the ones on the drum.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How to remove drum
i would call a service tech,it is not easy
Jan 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
242 people viewed this question
Dan Webster
Dan Webster
Sal De
