Question about Regal Ware K6725 Kitchen Pro Bread Maker
Cooked loaf not coming out of the tin
Once the loaf is baked I am not able to get it out of the baking tin. I have to almost destroy the loaf to get it out. The paddle is still attched to the baked loaf but that it not a problem once I have the bread out of the tin.
  • 134 Answers
Sounds like the paddle is no longer non stick..
Might be worth changing it.
Posted on Feb 14, 2009
Why does my Sunbeam 5891 bread maker reset itself a few minutes into baking a loaf ?
If you have another setting, try that and see if it works without reset.
Oct 29, 2015 | Sunbeam Kitchen Appliances - Others
I forgot to enter the size of the loaf and I don't want it to bake for a 2lb loaf. I only added ingredients for a 1 lb loaf.
I would just check it around 40 minutes into the bake cycle. If it doesn't seem done let it bake another 5 minutes or so the shut the machine off.
Jan 23, 2015 | Toastmaster TBR15 Bread Maker
My maker wont start automaticly after h ingredents in
If you just finished baking a loaf your machine won't let you bake another one until it has cooled off. Otherwise the next loaf wouldn't come out right. Always open the lid on you machine and let it cool off for about 1/2 hour before starting a 2nd loaf.
Jul 07, 2013 | Cuisinart CBK-100 2-lb. Bread Maker with...
How many pounds is xl bread
an xl loaf would be determined by the amount of flour you use. a standard 2lb large loaf is made usingc 560gms (19.7ozs)flour. i make my loaves using 850gms (30ozs) flour. the end result is an xxl loaf. (i don't bake it in the bread pan. i have an extra large loaf tin. one thing to note, is when using more flour all the other ingrediants apart from the yeast need to be increased too . good luck.
jackie
Feb 16, 2013 | Panasonic SD-2501WXC Automatic Breadmaker...
I just baked one loaf, and was readying the 2nd loaf, entered settings, hit start and got this: "E:01" What do I do?
That is a temperature warning that is an automatic feature on bread machines. What the machine is telling you is that the oven chamber is still too hot from baking the last loaf. It does that to prevent you from starting another loaf and having that loaf fail due to the high heat killing the yeast. If you want to bake more than one loaf unplug the machine after baking the first one, raise the lid, and leave it open for no less than 20 minutes. It should work fine by then. If not let it cool off another 10 minutes. It will be cool enough by ½ an hour to start another one.
Mar 26, 2011 | Breadman TR555 Deluxe Rapid Cool Touch...
I do not know when to take out the kneading paddle out of the breadman TR555LC. If not taken out, the Kneading paddle will stay in the bread itself after bake.
you leave the kneeding blade inside , i now its a pain but thats how it is when youve baked your bread you turn the tin upside down and tap the loaf out but theres a hole where the needer has been ,,i have looked at every bread machine on the market and there all the same.....
Jan 23, 2011 | Breadman TR555LC Bread Maker
Bread machine turns on when plugged in and when turned off with the on/off button and unplugged/plugged- it still keeps turning
i'm having the exact same problem! the last loaf i made after it was baked it started turning and it destroyed the loaf. now when i plugg it in, it wont stop spinning!
Jan 11, 2010 | Oster 5834 ExpressBake Bread Maker
Every time I bake a wholemeal loaf, it bakes well enough, but it tapers off to one end. This problem does not seem to occur with white bread, which rises evenly throughout the length of the loaf.
Fast Action Easy Bake yeast is supposed to help with improving the volume of a loaf, but you can add 1/4 tsp of Vitamin C powder (ascorbic acid) to whole wheat loafs to improve the rise. Sometimes mixing the flours helps as a small amount of white (30%) can make the loaf less dense. Make sure you use the best quality flour you can afford - the cheap ones don't always make such a good loaf.
Jul 14, 2009 | Panasonic SD-YD205 Bread Maker
Bread not done but timer went off
Perhaps the size of loaf selected was not the correct one for the amount of ingredients. Small loaf selected won't bake as long. Try selecting the larger loaf size and it should bake long enough. Also be sure you measure the water or other wet ingredients carefully. Good luck!
orleydog
Apr 03, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
116 people viewed this question
Top Regal Ware Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
