Question about Acer AL1916B 19" LCD Monitor
Acer A1916 does not power on
I have an Acer A1916, and I get no response from the power button. I got my hands on the manual and troubleshooted the pins: it says to test U701 and U702 pin 2 for 3.3V, I get 3.3 on U702 pin 2, but not on U701 pin 2. U701 is a set of traces, while U702 has actual components on it. There are no transistors that appear bulged, and the other traces check out (CN701 pins 5/6 @ 12V and CN701 pins 9/10 @ 5V) from the power board jumper to the main board. Does it sound like a dead main board?
Try checking for a short between pins 2 and 3 on U406. I had the same problem on 3 monitors. I removed this component from 2 of them and replaced it on the 3rd and all three of them work now. I am unsure of this components purpose.
Andrew
Posted on May 08, 2009
  • 1,602 Answers
TAKE IT TO A TV AND REPAIR PLACE AND SEE IF IT IS WORTH FIXING MOST PLACE WILL TELL YOU IT IS NOT WORTH FIXING THE COST FOR LABOR NOT THE PARTS PLUS ANY DIAGRAMS THEY HAVE DOWN LOAD WILL BE CHARGED TO YOU IN ADDITION TO YOUR OVERALL COST ACER HAVE 19 INCH FLAT PANAL SCREENS AROUND 120.00 DOLLARS
BUT IT IS UP TO YOU
UNLESS YOU WERE SMART AND BOUGHT THE EXTENTED WARRENTY ON THE MONITOR.
ROD
Posted on Feb 12, 2009
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
How to troubleshoot no power button response after CMOS battery removal and reset?
Did you reset once the power was turned off to the desktop and all residual power was drained before moving the jumper?Seems not - from the info supplied which has damaged the circuitry in the board.
Sep 01, 2014 | HP Pavilion dv6815nr Notebook
I need a wiring diagram for an acer aspire m1610. I replaced the motherboard and now it powers on but the button doesnt power it off and im getting no signal to my screen, plz help
Doesnt power off:
I think your front-panel cables arent connected properly. (the picture might be wrong, because not all front-panels are the same)
No video signal:
The problem isn't with your monitor, it's wth your video card, motherboard, CPU or power supply. Do you get the single beep at startup?
Jun 28, 2011 | Intel Motherboard
Hai,I had a problem with my acer aspire 4720 notebook, my notebook can not be fired when I press the power button, only the LED lights are lit and then die back, can you help me
Hi, lets try to problem solve. I would first try to gently push down on your power cord where it
enters your laptop to see if you get a response while you are powering on our laptop. If you get some sort of response then maybe its a loose connection and you will need to replace your power board. Gently wiggle it to see if its loose. Next troubleshoot would be to remove one of your memory chips.. then power it on to see if you get a response.. then maybe
swap them around to see if the issue is your memory. Does your laptop make any beeping noises? Take a look at your power cable to see if the light is on (if there is a light) I don' t think
there is one with the 4720. Maybe you can try to power on without the battery to see if you
get a response. Then maybe try with the battery with the unit unplugged. Try these things
and give us some feedback on your progress.
Jan 27, 2011 | Acer Aspire 4720 Notebook
Laptop acer aspire 5740g. No light indication when i connect ac adapter and no response when i press the power button totaly dead.What is the problem
My laptop been droped.
Dec 16, 2010 | Acer Computers & Internet
I have a problem with my Acer Ferrari One computer. The screen turned black after low battery and now we can't make it work. I don't know where is a problem. Can you give me some advise what can I do?...
Hi. Try troubleshooting steps below if the computer is still turning on after you push the power button.
Take out the battery
Unplugged the power adapter
Press and hold the power button for 30 secs
Plugged everything back in
Power on the computer
Jul 25, 2010 | Acer Ferrari One FO2001799 Netbook
My Acer Aspire 5532 touchpad is locked and all the responses that say FN F6 and FN F7 do not work. Help
The touchpad lock button on the aspire 5532 is just to the left of the power button (the one with the hand logo). worst placement ever, i accidentally hit it all the time.
Jan 22, 2010 | Apevia Acer Aspire AS6530-5514 Laptop
No video and no power down with power button...
when you replaced the motherboard did you remember to plug the power supply into the 4-pin square connector [to the left hand side of the propcessor!]
that should sort it!
Oct 14, 2009 | Acer Aspire™ T180 PC Desktop
Acer AL1916B 19" LCD Monitor Logo
761 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
