Question about Canon PIXMA MP160 All-In-One InkJet Printer
How do i increase print size
After setting up on microsoft word go to print &size of print decreases
Save the picture to your computer, go to paint, select it, enlarge it, and print it. If you found this helpful, post a solution or something and say this was helpful.
Thx.
Posted on Feb 14, 2009
How do I increase text size
Are you referring to the default text size Vista uses? Then, contrary to windows XP, in Vista you have to separately increase the text size for different instances.
1. Right click on the desktop and select personalize
2. Select Windows Color
3. Select the required item of which text size is to be increased.(for example: Icon, Message Box etc.)
4. Then you can change the text size, font, color, and font weight
Sep 19, 2010 | Microsoft Windows Vista Home Basic for PC
How do I increase size of print in web pages on Windows7?
"ctrl +" to increase the size and "ctrl -" to decrease the size
Aug 11, 2010 | Computers & Internet
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
How do I set photosmart B209 to enlarge copies?
http://h10032.www1.hp.com/ctg/Manual/c01796502.pdf
Pg 57 Item c, where is says touch size, instead of fit to page, you should have other options to increase or decrease the size.
Another option it to scan the item to the computer then print and enlarge during the print process
Mar 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printed font size on gmail
hi,
1) CTRL + to increase font size
CTRL - to decrease font size
CTRL 0 (zero) to set it to the default size as defined in your
web browser
2) Set the size again, if necessary, in your browser
or
Try changing the text size in View\Text size in the Explorer menu.
Apr 05, 2009 | Google Gmail
Your font and font size are set up in word. Depinding what version of word you are useing as to where this option is. If you look at the top of word screen, you should see a box that lists the font and font size. If you can't find it, go to help and type change font size and it will walk you through how to change your font size.
Mar 05, 2009 | Brother MFC-5840CN All-In-One InkJet...
How to increase the font size when printing?
I am sorry to say that font size cannot be changed from the All-in-One software. It can only be changed from the application which you are using to print.
Notepad and Microsoft Word
Please perform the steps given below, if you are printing from note pad nd Microsoft word:
Click on Format.
Click on Font.
Select the desired font under Size.
If you are printing from any browser, then I request you to perform the steps given below to change the font settings in differ browsers.
Following are the instructions to decrease or increase the font size in various browsers:
Change Text Size in Internet Explorer
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Size" option from the drop down menu. Use the mouse or press the x key.
A sub menu option window will appear containing the following five choices: "Largest", "Larger", "Medium", "Smaller" and "Smallest". "Medium" is the default value.
3. Select from among the five options by using the mouse to highlight or by pressing the appropriate keyboard letter, i.e. g for "Largest", l for "Larger", m for "Medium", s for "Smaller" or a for "Smallest."
The size of the text displayed in the browser window will change in accordance with your choice.
Change Text Size in Mozilla/Netscape 6+
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or Windows users can press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu window will appear containing three sets of options for changing displayed text size:
a. Increase or decrease the text size by small amounts. Select either the "Smaller" or the "Larger" option. Use the mouse to select "Smaller" or "Larger"; alternatively, press the appropriate
shortcut: CTRL - (minus) for "Smaller", CTRL + (plus) for "Larger". The size of text displayed in the browser window will increase or decrease by small amounts in accordance with your choice.
b. Change the text size to one of 7 pre-defined percentages of the default: 50, 75, 90, 100, 120, 150 and 200 percent. Select from among the 7 pre-defined percentages. Use the mouse to highlight your choice or the appropriate keyboard short cut, i.e. 5 for 50%, 7 for 75%, 9 for 90%, z for 100% (the default), 1 for 120%, 5 for 150% or 2 for 200%.
c. Change the text size to an arbitrary percentage of the default, e.g. 300%, 37.5%.
Select the "Other Options" menu item. Use the mouse to highlight your choice or press the o shortcut key.
A pop up input window titled "Text Zoom" will appear.
Type in the percentage amount by which you wish to change the default text size. Click on OK or press the ENTER key.
The size of the text displayed in the browser window will change in accordance with the value you enter in the input field.
These three options may be used separately or in combination.
Change Text Size in Firefox 1.0
1. From the Firefox Menu Bar select View>Text Size>Increase
2. This will cause the text to display on the web page one size larger. However this is a temporary change.
Or use the keyboard:
1. Press Ctrl & +/-, or Ctrl & scroll down/up to increase/decrease the text size.
To make a permanent font size change:
1. From the Firefox Menu Bar,
a. Windows: select Tools>Options. Select 'General'
b. Macintosh: select Preferences.
2. Click on 'Fonts & Colors'.
3. Set the font sizes. Minimum font size.can also be set.
Change Text Size in Opera
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse to make a selection or press the ALT + v shortcut keys. A drop down menu will appear.
2. Select the "Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu will appear containing the following options: 50, 80, 90, 100 (the default), 120, 150, 200 percent. In addition, there are four more options that make percentage increments or decrements to text size: -100, +100, -10 and +10 percent.
Select from among the options by using the mouse to highlight your choice.
* Alternately, use the + (plus) and - (minus) keys on your keyboards number pad, or the Zoom selector in the toolbar.
Dec 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer font size
Click on Format.
Click on Font.
Aug 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Size of font on the printed page too small
It depends on the print settings of the application but not All-in-One software.
Please perform the steps below to resolve:
Click on Format.
Click on Font.
Jul 15, 2008 | HP Photosmart C6100 All-In-One Printer
Change font size
Two things you can try!
1.From your Browser you can change text size in the browser.
I am using Internet Explorer for this example
Click on View from the top tool bar, Select Text Size.. you can increase and decrease the text size of a web page.
2.Before you print check Print Preview and Increse the page size.
My Browser defualt to Shrink to Fit,
I can change that to 120% and it will print the page very large.
Most programs in Windows will offer a Print Preivew
there you can make adjustments, and this can also be accomplished with Page Set Up..
Hope this Helps
Jul 03, 2008 | HP LaserJet 4 plus Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
116 people viewed this question
old marine
old marine
