Question about Hitachi Travelstar 80 GB Hard Drive
Can't Find Hard Drive.
Ok so My laptop crashed a while ago and I just got a new one. Now My problem is I took my old notebook's hard drive and put it into a USB external hard drive case and Pluged it in... the computer reads that it's there and I can feel the hard drive running but when I go to my computer it isn't there. Some one suggested to right click on my computer and go to manage and then to disk managment. I did but it doesnt even show up there. How do I find it.
  • Greg Caudle May 11, 2010
    Your hitachi drive should has jumpers pins on the rear. Make sure that the drive is in the slave mode.
  • Hitachi Master
  • 10,045 Answers
Go into the notebooks bios and see if there is a boot from USB in the boot sequence section. If there is, then enable it. If there is none, then it will never boot from an external drive.
Posted on Jun 27, 2017
  • 6966 Answers
SOURCE: hard disk acess problem
Hi, What the message mean is that Windows can not read/understand the filing system (something like the Table of Contents in a book) and therefore do not which and where are your files in the 80Gb. A few things you can try: 1. Run Windows Scandisdk on the Hitachi 80Gb; 2. Run any third party disk check/utility such Norton Disk Doctor. Alternately, you can use a file recovery software (such as GetDataBack) to recover/copy all your important files from the 80Gb and transfer them to another mass storage device. Thereafter, you can re-partition and re-format the said Hitachi to start new/fresh/clean. Hope this be of some help/idea. Post back how things turnes up or should you need further information. Good luck and kind regards.
Posted on Oct 06, 2007
SOURCE: Hitachi 500 GB sata Hard Drive
i have just format my compter now im haveing problums geting my sata hard drive back in i have the floppy disc what came whith it not shore how to install it
Posted on Jul 09, 2008
  • 82 Answers
SOURCE: External hard drive device installer error
Has it got its own power supply or is it using a two USB ended cable. It could be your laptop cannot supply enough power via one USB port so that it really needs a two ended cable so that two USB ports will power it up. Try this Mark
Posted on Aug 19, 2009
  • 51 Answers
SOURCE: External Harddrive doesnt show up in harddrive management.
it sounds like a hardrive issue. You can have the data retrieved from your hard drive by using this online company that I highly recommend:
Posted on Aug 31, 2009
  • 6831 Answers
SOURCE: how to use hitachi simpletouch external 320gb hard
If the HHD gets power and you can feel the drive spinning, you can try these steps and see if your problem is solved. Go to:
control panel
Administrative tools
Computer management
Disc management
Now you should see your drive in the schematic below. Right click on it and choose the option to change drive letter or paths. Now just assign a new drive letter to the drive, restart your computer and it should work fine.
If you cannot see any power light flickering or feel movement on the drive when you power it up, then there is a other problem. Hope this can help you.
Best regards
Posted on Nov 03, 2009
Over a year ago my acer 5315 laptop stopped working as im not sure why since then i have brought a new laptop, but on the acer it has some old docs and stuff
Ti retrieve the data from your old laptop, remove the hard drive and insert the hard drive into an USB hard drive adapter and then connect it into the USB port of your new laptop. Your new laptop will see this as an external mass storage device and you can then open the various folders and files on this hard drive to copy or view them.
If your new laptop cannot detect this hard drive, then the hard drive is faulty.
If you desparately need the data off this old hard drive then there are companies that can retrieve data off faulty hard drives BUT it will cost you and arm and a leg for their services.
Aug 20, 2011 | Acer Aspire 5315 Notebook
Hi, any ideas how when I took the hard drive out of the exact laptop.\r\nIt came out of Gateway MX7122. The screen broke on 1 so I took the hard drive out of broken one and put in the good machine that had...
Please reinstall the operating system on the new drive you kept and install ALL drivers. Even after installing all the drivers if you face any problems, there might be some other problem might be present in your laptop.
Hope this helps to you. .
Jun 28, 2011 | Gateway MX7122 Notebook
My Acer Aspire 9302 laptop will not boot up. It worked perfectly until yesterday and I can hear the hard drive whirring but its green light only stays on for about a second and then nothing happens. I've...
The system disc probably did not come with the computer. You could burn one if the computer is functioning correctly. However, you may consider getting a full version of Windows 7 32 bit and trying to install it through the DVD drive.
You'll have to set the BIOS to boot from the DVD drive once you have the install DVD from Microsoft.
Luckily, Windows 7 can be used on many computers that came with Vista or XP originally, without upgrading the hardware.
The Windows 7 operating system costs about $119.99 depending on where you get it.
This operating system can breath new life into your old laptop, which otherwise may require replacing.
If the hard disk drive actually crashed and is not recoverable, you may have to replace that hardware part, but hard drives aren't too expensive these days.
Good luck on this repair.
Jan 14, 2011 | Acer Aspire 9300 Notebook
My hard drive crashed...i took it out and placed it back in and now i get a black screen..what do i do
try to turn it on without hard disk, if it is OK, your hard disk is in trouble
Apr 10, 2010 | Dell Latitude D800 Notebook
Hard drive crashing
What size hard drive is it?
There is a know problem with Seagate 80GB sata 2.5 Mobile Hard Drives (example Apple Macbooks 2005-2006 had these drives), The drives were extremely faulty and several manufactures have extend their warranty's to 3 years for these faulty drives.
Feb 25, 2010 | Gateway MT6705 Notebook
Averatec serie 3200 crashed new hard drive need drivers
the same way you typed it here try google it gives you the drivers then you install.
Jul 04, 2009 | Averatec 3200 Notebook
Hard drive crashed
Nope, it's just a matter of pulling the old hard drive and putting in the new one. Sometimes there will be an adapter attached to your old drive that you'll have to transfer over to the new one. What you need is a 2.5" mobile PATA (IDE) drive.
May 28, 2009 | Toshiba Satellite A15-S129 Notebook
Cannot get Toshiba P@% S507 to see new hard drive.
you can't use a restore disk made for a specific hard drive with a much larger hard drive. This information is checked by the restore cd. You would need to contact toshiba and get a regular windows install cd.
Apr 01, 2009 | Toshiba Satellite P25-S507 Notebook
Hard drive.
since that it crashed, it is more practical that you reformat it, rather than buying new one. it is the system crashed not the whole hard disk and there is a great chance of reviving it , you have the recovery disk with you, then better use it than buying.
have a nice day
ally (allen)
Jun 27, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
I had a computer crash I bought a new computer and put the hard drive from the old one as second
yes it is working but I cannot see any of the admin files... I can see the user files.
Any suggestions?
Mar 23, 2008 | Acer Aspire 5500 5570-2609 Laptop
Hitachi Travelstar 80 GB Hard Drive Logo
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
