Question about Maytag PAV2300 Top Load Washer
"fabric softner staining the clothes"
"fabric softner is going into the machine but not washing off from the clothes. it is staining the clothes and left inside the machine after it is done through the cycle"
  • 530 Answers
Make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Posted on Feb 16, 2009
White clothes come out stained
AT LEAST YEARLY YOU HAVE TO CLEAN WASHER ORTHER VICE STAINED COMING NORMALLY.. YOU HAVE TO CLEAN WITH OXSY CLEANE LIKE BORAX,CLOREX,,
Jan 20, 2014 | Miele Washing Machines
My top loader whirlpool (3yrs old) appears to be causing stains: after careful monitoring it appears the fabric softener container conitunes to leak/drip/run down the central column - so staining sheets,...
You can try a few differnt things, staining is usually caused by not hot enough water to disolve or hard water issues. A Washer cleaning use one gallon white vingar fill up washer with hot HOT water let sit over night than run washer next day on HOT hot. Second try washing in warm to hot water dluting softner more breaks down better. Also dluting the softner more in the cup will help washing in cold causes alot of these issues, Make sure water heater turned up hot enough, make sure washer has hot water fill?
Aug 23, 2011 | Whirlpool Washing Machines
Kenmore 70 series, leaves browb lines on clothes. is there cleaning procedure for the washer?
It could be coming from your fabric softner. I know when I use liquid fabric softner I get oily looking stains on clothes. I no longer use liquid softner. I also use Dawn dish soap in my washer. I use Dawn instead of any other stain removers. Dawn dish soap works on everything.
Dec 02, 2010 | Kenmore Washing Machines
OIl stains on clothes with front loading LG washer
ftr loader washers do not have any oil, my guess would be you are using fabric softner . that can stain clothes. dilute with water, they are very concentraded. or your dispenser may not be working properly and not releasing softner at the proper time.i would run a clean cycle through it. meaning set on a hot wash- regular cycle no clothes and run wirth bleach in bleach disenser. do this every other month to keep washer clean hope this helps. make sure its not happening in the dryer , the dryer has frt and rear seals that go bad and start leaving marks on clothes and catching them in beteween the tub.
Sep 16, 2009 | LG WM-2032H Front Load Washer
"grease" stains on whites and light colored clothes
Run A Load With No Clothes And Put some Goo Gone In There. May Help.
Jan 05, 2009 | Frigidaire GLTF2940ES Front Load Washer
Hoover 800 RL toploading washing machine
if you use liquid fabric softner that is what it is sort of looks like grease what happens is that softner gunks up and gets up under the agitator then when your lighter clothes are washing it shows up you need to take some stuff called washer magic and just follow the directions on the bottle
Jan 01, 2009 | Washing Machines
Washer leaves fabric softner stain on white clothes
Dispenser wholes are probably clogged and all the softener is not dumping when it is supposed to!. Top loaders usually have a little cup like place to add the softener in the top of the agitator!
Those the Manuel tells you to rinse with water occasionally!
If you can't figure it out, call service and get it done and over!
You will feel better!!!
These guys are good
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jul 28, 2008 | Maytag Performa PAV2200
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Mile 864 front loader - clothes come out with new grease marks
Problem will be the use of fabric softner or too much detergent. The stain you are seeing is generally to animal fat that is present in fabric softner, Best solution is to cut back on the amount of softner being used, same with powder.
Sep 18, 2006 | Miele W864 Front Load Washer
Maytag PAV2300 Top Load Washer Logo
242 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
