Question about Fujitsu AMILO D-7820 Notebook
Replace the screen hinges
Hi everybody, i need to change the two hinges of the monitor in my Amilo 7820. It was easy to open the case and remove the monitor, but how i can open the monitor chase and remove the hinges? Ok, i removed the screws, but the case is like glued. Thanks to all...
  • lollodj Feb 12, 2009
    Thanks Rod, but the pc case is still open in any parts, it was easy, and i removed the monitor. I can't open the monitor case, the frame around the lcd i mean, where the hinges are locked. I removed 5 screws, but the frame is still closed, i think it's a sort of block that i can't find.
  • 1,602 Answers
LOOK UNDER NIETH THE FEET OF THE COMPUTER AND YOU MAY FIND SOME SCREW SLOTS, OR A MANUFACTURE LABEL IS PLACED OVER A SCREW HOLE TO KEEP PEOPLE OUT OF THE COMPUTER.
LOOK IN THE HARD DRIVE, BATTERY AREA, COOLING FAN AREA FOR EXTRA SCREWS,
THEY ARE SNEAKY WHERE THEY HIDE THE SCREW HOLES AT
LAST BUT THEY MAYBE SNAPPED TOGETHER AAND VERY HARD TO TAKE APART.
GOOD LUCK
ROD THE CANDYMANGANDY
Posted on Feb 12, 2009
Amilo 1818 - the screen is using the hinge one side, but bending the metawork the other. What do I need to do to fix this problem? Regards Deb
Hi
You could replace the broken hinge have a look here
http://shop.ebay.co.uk/?_from=R40&_trksid=p5197.m570.l1313&_nkw=Amilo+1818+hinges&_sacat=See-All-Categories
there will probably be other places on there as well
good luck
if you dont have a manual www.amilo.com go to support/downloads then look for manuals
but you will need adobe reader installed to read the manual
and if you do download the manual it will give you an option to save it so if you save it to your desktop or documents you will alway have it for easy or future use
Feb 01, 2011 | Fujitsu AMILO PC Laptops
How to open back panel od Amilo D 7820?
@cbacer
a faulty/ flat or removed CMOS battery
results in a warning that Time and Date have to be reset
and that default cmos settings for bios are in use
(i have the same labop an tried it out 5 min ago)
however not everything is lost: a bios password will not be removed
to remove the bios battery you have to tild back the display
all the way back until its horisontal
with a flatt screwdriver(vertical) inserted between the display an the cover of the hinge slightly push the screewdriver away from you (to release the plastic clamps from the backside of the hinge-cover)
do this on both sides
remove the hinge cover (be aware the power button cable is still connected to the cover and should not be forced)
now you can see 3 screws from the keybord , remove them and pry open the keybord beginning nearest to the display
(dont froce the flatt cable under the keybord)
now you see lots of aluminum plating.
you have to remove the one on the upper right side
and the one in the middle (pay attention not to lose any screws inside the labtop they probably short out something)
the cmos battery is wraped in blue rubblefoil and connected to
a smal connector
-be aware this is no trivial endevor.
-you have to be grounded at all times (electro static discharge up to 200kV is mighty destructive when it comes to computer organs)
-if your doing this the first time get somebody to assist you and -take pictures every step of the way so you can retrace you steps
-get a few smal containers for the different types of screws
-use tweezers and not magnets to retreave lost screws
-never ever use brute force, computer designers do not consider
structural integrity a hight priority
Feb 08, 2010 | Fujitsu AMILO D-7820 Notebook
How to open the back panel of fujitsu AMILO D 7820
u can use the software herionee to change the password ...if not use the guide which is given to u with the lptp t
Feb 05, 2010 | Fujitsu AMILO D-7820 Notebook
Screen has moved to sideways display7
right click on an empty area of the desktop > scroll down to where you would see something like Nvidia control center or ATI control center. Open the control center and look for display orientation, this is where you can change the orientation of the screen.
Nov 08, 2009 | Fujitsu AMILO D-7820 Notebook
Amilo d-7820... Sound driver failing install.
Bad, or obsolete, driver. Uninstall the one you have now and get (as in Save, not Run) the latest version directly from Fujitsu.
Oct 18, 2009 | Fujitsu AMILO D-7820 Notebook
Screen dont open
Lets diagnose the problem:
- if you have CRT Monitor try to connect your Laptop and check it if they have display screen?
- if CRT Monitor have display your LCD have a problem.
Let me know your problem is solve?
Sep 25, 2008 | Fujitsu AMILO D-7820 Notebook
CMOS
open the screen flat out, carefully prise up the plastic over the two hinges, remove the three screws holding the keyboard in and then the metal flap beside the heat sink, it is under there, you need a cmos battery with 2 wires connected to a plug, as yet i havent found a source for that, i used a standard battery and taped the two old contacts to it, worked for 18 months ok
Jul 19, 2008 | Fujitsu AMILO D-7820 Notebook
How do I change the CMOS battery on my Fujitsu Siemens Amilo D 7820?
My best suggestion, is to remove the CD Drive, Battery, and Hard Drive. THen undo all of the screws on the back panel. There is no easy access panel to do this, you have to remove the entire back panel. once you have the back cover off, it should be pretty easy to replace the battery.
Feb 05, 2008 | Computers & Internet
Amilo d 7820
Try powering the laptop on without the battery in (AC plugged in). If it works, you need a new battery.
Dec 06, 2007 | Fujitsu AMILO D-7820 Notebook
Compaq Presario Laptop (M2000 series) hinge
Very easy to replace if you can get new ones. Remove the batter and remove all screws under the battery as well as all the screws to the right and left of the battery location (3 on the V5000). Now back on the other side gently pry up on the portion of the "keyboard area" directly above the keyboard. A small keyboard will make this handy
Now you'll see screws holding the monitor the the notebook. Remove those screws and the monitor will be freed. Be careful with the wireless antenna wires and xvga cable. Now remove all the little rubber pads from the monitor and you'll find all the screws underneath. Remove those and you'll see how the hinges are attached to the monitor. There are three screws directly to the screen and a few to the frame on each side. Remove those and the hinges will come off.
Replacement hinges are available from HP's website for about $50 + shipping but call them up and give them *hit and see if they'll help you out.
Nov 01, 2007 | Compaq Presario M2000 Notebook
Fujitsu AMILO D-7820 Notebook Logo
175 people viewed this question
Top Fujitsu Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant  Sharma
Prashant Sharma
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
