Question about HP Pavilion ze2000 Notebook
Reboot back to factory settings
Can i reboot with out the cd/drivers how do i factory restore
  • HP Master
  • 4,806 Answers
Hi there
You can only perform a restore if the PC came with a recovery partition or recovery CD's.
Recovering the system without using Windows
  1. Disconnect all peripherals and internal non preinstalled devices from the PC, except the monitor, keyboard, and mouse.
  2. Turn on the computer.
  3. When the initial blue HP screen appears, press the F10 key repeatedly until a recovery menu appears. The progress indicator that first appears does not indicate that a recovery is taking place. The progress indicator represents the time before the recovery process is started.
  4. When the Recovery screen appears, click Next, and then click Yes to perform a normal, non-destructive recovery.
  5. To perform a destructive recovery, click Advanced, and then click Yes.
  6. After the System Recovery is complete, and the computer starts successfully, update the computer software
Post back if this does NOT work
Good luck and thanks for using Fixya!!
Posted on Feb 12, 2009
  • Lee Hodgson
    Lee Hodgson Feb 12, 2009
    Try this way then.
    Recovering the system from the Windows XP desktop
    2. From the Windows XP desktop,
      click Start, All Programs, and
      then HP Tools.
    3. Select HP PC System Recovery.
      The Recovery screen will appear with the
      question Do you really want to start HP PC
      System Recovery?
    4. Click Yes, to continue
      the recovery process.
    5. When the Recovery screen
      Yes
      recovery.
    6. To perform a destructive
      Yes.
    Good luck
Can I reset it back to factory setting with out a CD or DVD
If the restore partition is still on the hard disk then press Alt and F10 just before it boots. Otherwise try T8 just before it boots. If this fails try Creating a System Rescue USB drive (Note: An alternative to the spyware-laden Daemon-tools for mounting the ISO file as a virtual CD-ROM is Virtual CloneDrive). If you have trouble with the System Rescue CD, you can try some other distros.
Reboot the netbook and go into the Acer BIOS settings. Change the boot settings to check USB first. Plug in your System Rescue stick, and restart the netbook.
Run "wizard", and launch gtparted (icon towards the lower-left of the screen).
Delete partition 2, create a new one, then reformat it as NTFS
Mark partition 1 as bootable (right-click, edit flags). Remove USB drive.
Reboot into the Acer System Restore software. Choose to restore the system.
Plug the System Rescue USB drive back into the Acer netbook.
Reboot into the System Rescue CD/USB, go back into gparted, and flag the restored partition 2 as bootable.
Remove USB flash drive and reboot.
Hope that helps.
Jan 11, 2014 | Acer Aspire 7720 Notebook
I want to restore my dell inspirion 1721 to factory settings i try the f8 key option but in the advanced boot options there is no "repair your computer" option. what can or should i do?
Your laptop should of come with a disc to restore it back to the factory setting what windows are you running?There should be a restore point you can go back to
Jan 12, 2013 | Dell Inspiron 1721 Notebook
I restored my acer aspire one back to factory settings without a back up device. when I try to restore from disk with an external cd. it says my disk is incorrect. it was the disk that came with it.
In that case, only the seller can solve it replacing the disk or your CD drive that I did not want to mention but seems to be your problem. Before calling them, try to disable the CD driver in Control Panel, reboot, Enable the driver, reboot and try the cd again.
Aug 10, 2011 | Computers & Internet
How do i reboot emachines
Hi! Welcome to www.fixya.com.
  • Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.Press F1 when the black screen appears; you will enter the setup configuration mode. You will be presented with a menu.Select Restore Factory Defaults. Your computer will do all the work for you. As with the CD, this process may take several hours.
  • Read more: How to Reboot a Computer Back to Factory Settings ' eHow.com http://www.ehow.com/how_4479794_reboot-computer-back-factory-settings.html#ixzz1SPR0nI9L
    Hope this resolution fix the problem on your computer.Thanks for contacting Fixya. God bless. Bye for now.
    Jul 17, 2011 | eMachines Computers & Internet
    Emachine 3653 factory restore
    You can use the Restore CD that came with the computer. The eMachines restore disk sets your PC back to factory settings with the original operating system and programs that were shipped with the computer. Doing so resolves many problems that can arise from long-term computer use, viruses, or the operating system slowing down.
    1. To do a factory restore insert the restore CD then reboot the computer. When prompted, press any key to boot from the CD.
    2. Select the option to "Reformat the drive to factory settings."
    3. Follow the on-screen instructions to reinstall the operating system and original software that came with your computer.
    4. Once the Restore finishes, you can re-install all the programs that you added to the computer as well as restore your files.
    Reminder: Reformatting your computer erases all of your installed programs, personal documents, pictures and music. If you have the ability to, back up all of your personal data using a removable flash drive, external hard drive or DVDs before doing a Factory Restore.
    Apr 06, 2011 | Computers & Internet
    How do i reboot my laptop back to factory settings
    To reboot to factory setting you need to have the restore disk from the computer, put it in the drive and restart with the cd in the drive, if the startup screen does not start right away you need to type f11 or f6 to change startup order to cd first the the restore screen will startup and click restore factory settings
    Jun 04, 2010 | eMachines eMD620-5133 Notebook
    Reboot my Acer Notebook
    Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
    Mar 05, 2010 | Acer Aspire 3100-1405 Notebook
    How do you Reboot a computer back to factory setting
    Instructions Things You'll Need:
    • Factory Settings CD
      How To Use the Restore Factory Setting CD
    1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
    2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
    3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
    4. Step 4 Reboot the computer to complete the process.
    5. How to Reboot Using the Computer Start-Up
    6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
    7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
    8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
    Jan 27, 2010 | Computers & Internet
    If you are having problems with your system and you want to restore it to factory settings .. as long as there is nothing wrong with the CD drive itself you do not need windows drivers for it to function properly during a factory restore
    Feb 02, 2009 | HP Pavillion ZV6000 Notebook
    I want to reboot my Toshiba A200 back to factory settings, i have a spyware down load **** that keeps on asking me to install.....how do i reboot
    If you have the recovery CD, then put that in the drive, reboot the laptop and make sure you boot to the CD. The recovery process will start up and you can restore the laptop to it's factory settings. Make sure you have all of your documents, music, etc. backed up.
    Dec 05, 2008 | Toshiba Satellite A205-S4617 Notebook
    HP Pavilion ze2000 Notebook Logo
    416 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
