Question about Maytag SAV2555A Top Load Washer
Belt i need to replace my belt on my washing machine. When i flipped it over i could not get the water pump off. so how do i get it off to replace the belt.
    President:
  • Maytag Master
  • 2,651 Answers
Ouch this ones a litle complicated, hopefully th eold belt is still connected??? youll need to drop the motor assy 4 1/2" bolts, and after you drop the motor assy, youll need to flip it over and removeth pump with a torx20 wrench ,after removing the pump you can install the new belt. the nreinstall.( put the 2 bolts holding rear of motor back on first, makes it much easier to remoint the front bolts. and watch placemnt of the belt around the pump legs, it makes a difference( which is why i hope theold belt is on, makes it easier to see how it hooks up. good luck
Posted on Feb 13, 2009
Washing machine not spinning
Check the belt. You might have to replace the belt of the washer. If the belt has deteriorated, you need to replace it.
If the machine does not spin because it still detects water inside, the problem could be in the pump. It probably has trouble draining water or pumping out water. If the pump has corroded, you can also try replacing it.
source: http://www.washingmachineadvisor.com
Dec 06, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Wont drain water
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 05, 2009 | Washing Machines
Washing machine will not drain
2. Water Pump
Aug 01, 2009 | Frigidaire Washing Machines
I have a maytag top loading washing machine that will not drain the water between the wash and rinse cycle.
2. Water Pump
Jul 27, 2009 | Washing Machines
Stop in mid cycle
HD= No drain.
2. Water Pump
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
My kenmore series 80 washing machine won't drain water. We have checked the hose and that is clear, what should we check next?
Check the following.
2. Water Pump
Jun 25, 2009 | Kenmore Washing Machines
My lg washer is not letting out the water after washing
HI, you will need to check the following below to combat this issue.
2. Water Pump
Jun 21, 2009 | LG WFT1071TP Top Load Washer
Whirlpool washing machine stops after wash cycle. Will not drain for rinse cycle
Check the following to address this issue. if all checks out ok, replace the timer/control.
2. Water Pump
Jun 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Wont empty out water after wash cycle
2. Water Pump
Jun 07, 2009 | Amana Washing Machines
AWZ 541D Machine will not drain water after wash. Error E102/E101? Please help.
Check the following to address this issue-- 1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). 2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed. Please rate and have a great day:)
Jun 03, 2009 | Whirlpool Washing Machines
Maytag SAV2555A Top Load Washer Logo
151 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
